Post pictures of your installation here! - Page 8 - RC Groups
Oct 05, 2016, 06:59 PM
Build more, websurf less
FlyingW's Avatar
BlueMax,
Well done on the 190.
How do you power the whole setup? One good battery to the Nano, and then from the Nano to both X10s?
Just one connection to make then - nice.
The Nano manual says that Xtreme Mode 1 is output on all Nano ports - so your idea of plugging two X10s into the same Nano might work.
Good luck with the plane; they were bad news to Allied bombers.
Paul
Oct 05, 2016, 07:04 PM
FlyingW's Avatar
Originally Posted by RyanNX211
I don't know if it was all that bright to leave the chrome windows in place, but they haven't been a problem with the XPS. There's still an exit hole in the fuse for another mfg antenna
Tom,
Many years ago I added Monokote chrome in the shape of a canopy to the top of my Kwik-Fli. It was right under the 72MHz antenna that was strung from just behind the front hatch to the top of the fin.
The next flight was full of glitches but I got her down ok. I removed the chrome piece and the glitches were gone. I suppose the Rx couldn't handle the reflections along roughly the same path as the antenna.
Since then I keep metallic stuff away from antennas as much as possible.
Be well,
Paul
Oct 05, 2016, 08:07 PM
CRS and CDS Certified
thebluemax's Avatar
Originally Posted by FlyingW
BlueMax,
Paul
thanks... The receiver battery is plugged into the battery port on the X10 via a No-No switch and the battery for the electronic ignition is plugged into port 10 via another No-No switch.
The Y harness comes off the Nano on port 3 with one end of the Y going to wire on the X10 in the fuse where both batteries are attached and the other wire from the Y harness goes to the wire on the X10 in the wing. When I attach the wire from the X10 in the wing to the Y harness I will put a clip on it to hold it together to keep if from coming apart in flight. So one wire to keep it simple when attaching the wing.
This picture is what the FW-190 looked like before the new paint job.
Latest blog entry: Aegis Aircraft F-117
Oct 06, 2016, 07:39 PM
FlyingW's Avatar
BlueMax,
What is a No-No switch?
Paul
Oct 06, 2016, 07:52 PM
thebluemax's Avatar
BlueMax,
Paul
A no-no switch meaning I did a bad thing by using switches as Jim says he does not like using them. So I was joking when I said that. The switches I use are the heavy duty ones from Electro Dynamics (EDI).
Oct 07, 2016, 12:26 AM
Yep, a no-no!
Feb 09, 2017, 09:38 AM
FlyingW's Avatar
This Nano went through the props of a small quadcopter in a crash. After the receiver was jettisoned the quad came to rest upside down on the ground with all four motors spinning at about 2/3 power! It is a good thing it was upside down or it would have thrashed around until it hit something else. I have to investigate what mistake(s) I made setting up the failsafe on the flight controller - I always want the motors to turn off if the aircraft finds itself without a receiver.
If I put heat shrink tubing over the exposed wires will it be serviceable?
Paul
Feb 09, 2017, 10:17 AM
Yes, shrink tubing works fine!
Feb 09, 2017, 07:32 PM
FlyingW's Avatar
Good as new.
Feb 10, 2017, 11:31 AM
Perfect!
Oct 21, 2017, 11:40 AM
My installations
KMX and SIG Wonder installations. Last one is the old 10 channel rx my old Midwest Extra and been flying for many years and was my first XPS RX!
Oct 21, 2017, 02:28 PM
Thanks for sharing!
Dec 23, 2017, 07:28 AM
XPS 10 channel RX installation
Busy mounting a XPS RX in my refurbished Skyfire.
Dec 23, 2017, 09:38 AM
FlyingW's Avatar
That's a great installation - puts the receiver up off the ground in the highest part of the plane in the turtledeck.
Will you make the connections first then feed it into position, or is that a hatch on the face of the turtledeck?
Nice job.
Dec 23, 2017, 11:59 AM
Thanks for your positive comments.
No there is no hatch. Going to connect up everything then tie the wires up onto the vertical section to reduce the stress on the RX plugs and pins. Also going to have two power extention cables down into the fuselage.
Regards
Charlie
Discussion Post your 2.4GHz Rx Installations here mwhitman Multi Task F3X 35 Sep 19, 2011 03:18 PM
Discussion Please post photos of your sensor installations here! billpa Eagle Tree Systems 8 Jul 09, 2011 06:21 AM
Gallery post all your modified revo's here!!!!! (even if you only have lights installed) car guy Nitro and Glow Power Cars 5 Jun 22, 2007 02:20 PM
The Blue Frog - Post your pictures & Feedback here! Hippo Foamies (Kits) 496 Feb 06, 2004 12:40 AM
Post your inverted chopper pictures here for a kick !!! gmamo Electric Heli Talk 19 Apr 09, 2002 04:13 PM
