Jun 07, 2020, 05:49 PM
Nano in wing
Hi Jim, firstly I hope you are all well on the other side of the Atlantic. I am fine but we have quite a strict lockdown here.
OK I'm busy with the complete refurbishment of my Yak 112. I used to fly it on 35mhz. Now I'm installing a X24 and a RFU in the cabin area. I also want to mount a nano in the one wingtip.
Now is it OK to run the wires from the nano with the servo wires to the X24 or must there be separation between the wires. I'm using powerbox twisted wires throughout. The wing is hollow moulded fiber glass construction. It has only two servo hatches for access.
Many thanks in advance.
Stay safe
Charlie
Jun 07, 2020, 09:59 PM
It is recommended that you always use twisted wires (like our SuperTwist wire) for connecting receivers to the X10+ and X24.
Jun 08, 2020, 03:08 AM
Thanks for your reply Jim, but can I run the NANO output cable with the servo wires or can it cause interference? All the wires are twisted.
Thanks.
Charlie
Jun 08, 2020, 11:42 AM
As long as the wires going to the Nano are twisted you can run them with servo wires.
Jun 08, 2020, 02:05 PM
Thanks Jim that makes my life a lot easier.👍
Jun 08, 2020, 04:37 PM
Just make sure the Nano is eventually away from the group of wires, like in the wing tip like you described.
Jul 11, 2020, 06:38 AM
Build more, websurf less
FlyingW's Avatar
XPS-J1 module in Taranis
Here is the XPS-J1 transmitter module installed in the external RF bay of a Taranis transmitter.
I've seen folks keep one antenna for the internal RF output and another antenna for the external RF output. Instead of having two antennas sticking out I just use the XPS 2.4GHz antenna on the XPS-J1 and put a dummy load on the internal RF output for protection.
When I switch to the internal RF capability I swap the XPS antenna to the internal RF output and put the dummy load on the XPS-J1. I do not switch very often so I do not think I will be placing too much stress on the antenna or connectors from repeated re-connections.
The setup works well and the hardest part is reproducing 30 years of airplane setups in OpenTX.
Jul 11, 2020, 08:04 AM
Another day in paradise
thebluemax's Avatar
I have the Jumper T-16 and have both antennas on the TX. What are you using for the "dummy load" and where did you get it?
Latest blog entry: Aegis Aircraft F-117
Jul 11, 2020, 08:37 AM
FlyingW's Avatar
I'm pretty sure it was this one from Amazon:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Jul 11, 2020, 08:41 AM
thebluemax's Avatar
ok. thanks.....
Discussion Post your 2.4GHz Rx Installations here mwhitman Multi Task F3X 35 Sep 19, 2011 02:18 PM
Discussion Please post photos of your sensor installations here! billpa Eagle Tree Systems 8 Jul 09, 2011 05:21 AM
Gallery post all your modified revo's here!!!!! (even if you only have lights installed) car guy Nitro and Glow Power Cars 5 Jun 22, 2007 01:20 PM
The Blue Frog - Post your pictures & Feedback here! Hippo Foamies (Kits) 496 Feb 06, 2004 12:40 AM
Post your inverted chopper pictures here for a kick !!! gmamo Electric Heli Talk 19 Apr 09, 2002 03:13 PM
