Sep 04, 2019, 10:44 PM
Another day in paradise
thebluemax's Avatar
Very cool. Nice. way to go...
Latest blog entry: Aegis Aircraft F-117
Oct 21, 2019, 02:48 PM
Hi Jim, would like your input on the RFU and X10 placement. The one RFU aerial will be down the side of the fuselage where the red line is and the other one go through a hole ( red dot) up into the canopy behind the instrument panel. Second picture of the aerial position in the canopy. The X10 will be slightly higher than in the photo.
Many thanks.
Charlie
Oct 21, 2019, 03:05 PM
This is the aircraft. The aerial along the inside of the fuselage will be above the wing and approximately where the blue stripe is.
Oct 22, 2019, 12:17 AM
j_whitney's Avatar
posted on thingverse?
Oct 22, 2019, 02:31 AM
I don't know thinsvers?
Oct 23, 2019, 01:47 AM
It is a place for 3d printer files so you can print it out yourself. or have it made and shipped to you.
Oct 25, 2019, 01:20 AM
This will work, but a range test will tell you everything.
If you were going to use a 2nd RFU I would place one in the belly towards the tail, with one antenna running parallel to the fuselage along the bottom, and the other antenna running vertically up one side of the fuse.
Oct 25, 2019, 01:53 AM
Many thanks Jim.. I always range check and make sure everything is perfect. I'll also make sure all the wires are as far from the RFU as possible. It's a scratch built Extra so will be extra sure.
Many thanks
Charlie
Oct 25, 2019, 03:25 AM
WOW! That's beautiful for a scratch built! Well done!
Oct 25, 2019, 06:23 AM
Thanks Jim, I did fly it quite a lot for a few years till the rudder servo packed up while flying and jammed full right. I could still keep it in the air but it was flying terrible and I never knew what was wrong. When I throttled back it immediately went into a spin. I got it out three times. Then eventually killed the engine and watched it spin in.
Well now it's rebuilt, recovered and painted and almost finished. Just waiting for all the vinyl stickers etc.
Used to be on 35mhz pcm but used to get glitches every now and again. But now it will be much better on 2.4 XPS! 😁
Nov 01, 2019, 03:41 PM
Hi, just some pictures of my x10+ and RFU installed with light pipes so I can see the status LEDs. Works great but I still have to neatly tie all the wires etc.
A funny thing I noticed when about to switch on I rotated the rudder servo (JR 8401) and the LED on the X10 and RFU both blinked red. I can only imagine it was generating some electrical feedback into the X10 bus. I've never seen this before.
Enjoy the weekend.
Charlie
Nov 01, 2019, 11:25 PM
Yes, servos will generate power like a magneto.
Dec 05, 2019, 08:25 AM
The Extra 300S flys.
Hi Jim, I had to go to higher C rated lipo batteries because I was constantly getting low voltage when operating the servos on the bench. Now I've got 2 x 2100 mah 25C life batteries and 16 awg power wires to the switch. No way can I get anything but green LEDs no matter how fast I operate the servos. I have 5 x JR 8401s and a std analog throttle servo. I did the maiden on Sunday and had about a 10min flight and everything worked flawlessly. Just some trim adjustments. I range checked before the flight without and with the engine running and there was zero range difference. So I'm very happy. Oh I'm using one RFU and X10+. Here are some pics from Sunday. 👍 😁
Dec 05, 2019, 12:30 PM
Very nice, and congrats! I am sure glad that YOU pay attention to the LED and what it means. You might be surprised by the number of customers who tell me all of the time that they fly with the LED yellow or blue! Yes, our products work down to either 1.8v or 2.1v, but man - if there is a warning indicator pay attention to it!
That plane is beautiful!
Dec 05, 2019, 03:15 PM
Thanks for the compliment Jim. I really can't believe someone would fly a plane with anything but green LEDs! Well there are no pills for crazy and it keeps the hobby shops in business.
Have a great day.
Discussion Post your 2.4GHz Rx Installations here mwhitman Multi Task F3X 35 Sep 19, 2011 02:18 PM
Discussion Please post photos of your sensor installations here! billpa Eagle Tree Systems 8 Jul 09, 2011 05:21 AM
Gallery post all your modified revo's here!!!!! (even if you only have lights installed) car guy Nitro and Glow Power Cars 5 Jun 22, 2007 01:20 PM
The Blue Frog - Post your pictures & Feedback here! Hippo Foamies (Kits) 496 Feb 06, 2004 12:40 AM
Post your inverted chopper pictures here for a kick !!! gmamo Electric Heli Talk 19 Apr 09, 2002 03:13 PM
