Tore the rudder this morning flying off grass. Funny thing was that i did not notice this immediately and kept flying. But i was commenting to myself that the back end was really loose. Duh!
No big deal, a couple of CA hinges will take short work repairs. To prevent future issues, i thought of putting a small foam block at the end of the tail just shy of the rudder. Should not affect water control, not sure about on the field. Any thoughts? |
I'll be adding a small plastic wedge from a pair used to protect lower wing tips from ground strikes. Have one on the Seamaster and built one from lite ply for the Polaris. This also protects the tail when operating from hard surfaces. Once worn it's easily replaced.
https://www.rcgroups.com/forums/show...ostcount=21334 |
thanks again for pointing that out! |
One thing it demonstrates is how nicely the model lands if you have smooth elevator control. That means good piloting skills AND accurate servo and linkage AND the right throws and expo AND correct CG. The poor landings we see at the field and on videos are nearly always due to lack of one or more of these factors. What sort of control settings do you use? |
I'll have to look up my settings and let ya know. Many Polaris pilots seem to land to hot, I like to throttle down and let it settle into a glide path and just manage the elevator. |
One man's grease is another man's bounce.
wet servo causes crashQuote:
New PU is in the mail. This time I'll seal the servo wires to the servo case, seal pushrod tubes with heat shrink tubing and vaseline, and monitor the wetness of the internal paper towels after every flight off water. Live and learn, Tony |
sorry to hear that...
I use vaseline on the pushrods to seal and line the internal cavity floor with rolled up papertowl to keep water from pooling. I then cover everything in front and rear cavities with papertowels before putting covers on. After flying in rough water, I have to replace the wet papertowels. |
It sure would be nice if a passageway was molded into the fuse halves that would connect the bottom of the servo pockets to the deep area behind the canopy. The passageway would allow the water that found its way alongside the servos to harmlessly flow to the deepest area where it would do no harm and easily absorbed up by a paper towel placed in the "bilge". |
Tony |
On my Gemini flying boat I filled the servo wells with urethane glue to keep water from getting under the servos. In that case, the servos are on the top of the wing and are always getting splashed.
http://www.modelracing.it/immagini/3123.jpg |
Thread Tools | |
Similar Threads | |||||
Sold | Complete Power set up for a Aero Models Aqua Cat or Polaris | RTflyboy | Aircraft - Electric - Power Systems (FS/W) | 1 | Dec 08, 2012 06:52 PM |
For Sale | cassini aero models usa p 51d mustang 120 arf | asteroidguy | Aircraft - Fuel - Airplanes (FS/W) | 2 | Mar 17, 2012 05:21 PM |
Discussion | Model Aero Polaris Seaplane Auction | Model Aero | Hot Online Deals | 1 | Mar 11, 2012 11:28 AM |
For Sale | cassini aero models usa p 51 mustang 120 arf | asteroidguy | Aircraft - Fuel - Airplanes (FS/W) | 0 | Feb 22, 2012 01:14 PM |
