Aug 27, 2015, 03:52 PM
Just Plane Nuts
Louierc's Avatar
Just an update after some flights of the AJ-404:
The 200 mAh LipO provides plenty of flying time, it flies well at half throttle
It will spin well with full rudder
It will glide somewhat with the power off. My down thrust and right thrust must be about right, since there is not much correction needed under power.
A fun plane to fly, just watch the wind and remember that it is not a foamie !
Aug 29, 2015, 02:39 PM
builderdude's Avatar
My AJ-404 Interceptor came in at 5.5 ounces when I built it, mainly because I added ailerons to mine. The maiden flight stalled due to not enough power. I had to upgrade the motor. Once I got a stronger motor in mine, it flew brilliantly.
One effect I've noticed about the extra weight was that it had a better glide slope. Beautiful power off glide, in fact.
I've discussed this at some length with Pat Tritle, and I think the reason why is because when the plane is light enough, the drag is greater than the momentum. When you increase momentum (a direct result of increasing the weight), then drag no longer exceeds momentum and a more normal glide slope is possible.
Sep 06, 2015, 09:15 AM
Pat,
Can you please tell me which motor you used?
Sep 06, 2015, 01:16 PM
P. Tritle's Avatar
Mad, The original AJ was set up with an E-Flite 180.
PAT
Sep 06, 2015, 01:31 PM
Thanks Pat. Appreciate the quick response.
Sold 6 ch r/c flight simulator for pc reble1 Aircraft - General - Miscellaneous (FS/W) 6 Oct 17, 2012 06:02 PM
Discussion Discount on rechargeable 3-CH R/C helicopter, up to 30% off Sandy90 Hot Online Deals 0 Sep 28, 2012 11:06 PM
Discussion Big Surprise from 3.5-CH R/C Indoor Helicopter Sandy90 Electric Heli Talk 10 Sep 06, 2012 11:22 AM
Discussion Every man's dream Rechargeable 3-CH Palm-Size Mini R/C Helicopter Sandy90 Micro Helis 15 Aug 28, 2012 04:13 AM
Discussion 40" Piper Pacer for IPS Power and 3 ch. R/C P. Tritle Scale Kit/Scratch Built 113 Jul 25, 2006 06:18 PM
