Dec 11, 2012, 10:21 AM
New Product
New 808 #20 HD Key Fob Camera
Just got one of these from BestDVR (who makes them apparently)
Records in MOV or AVI (only tried MOV so far)
MOV:
Video:-
Codec: H264 - MPEG-4 AVC (part 10) (avc1)
Resolution: 1280x720
Frame rate: 30
Decoded format: Planar 4:2:0 YUV
Audio:-
Codec: PCM S16 LE (sowt)
Channels: Mono
Sample rate: 32000 Hz
Bits per sample: 16
Main changes to previous models, 4 indicator lamps & uses a micro USB port.
Has 4 new modes:
Repeated stills (3) possible in still mode.
Sound Recorder
Motion Detection Recording
Driving Recorder
Initial test show video quality very close to 808 #15 but with better low light sensitivity. Sound much the same. The .mov recordings take around half the space of the #15 .avi recordings. I`ve not examined the dropped frame rate (if any) yet.
Problems encountered: Recoding onto a class 4 card works fine, but onto a class 6 card it records just approx 1 minute then appears to crash!
I`ll report any further problems/solutions as they arise.
Dec 11, 2012, 02:41 PM
Hi
I just saw your post about the new #20 keychain camera and have been debating about buying one since seeing them on eBay recently. I was just wondering if you could post a sample video from the #20 camera. I’ve been debating on whether to buy the new #20 camera or the #16 camera.
Ray
Dec 11, 2012, 04:40 PM
I'll put one up in a day or two.
I've done some more tests, switched to AVI, same video encoding method used.
With avi records onto class 6 card without issue.
Editing: AVI is broken & has to be converted first, MOV struggles so would be best converted too. Both feature around a 3 second gap between recordings, whether 20 min or 2 min.
I believe BestDVR is working on these & expects to fix with a firmware update.
On the plus side, I found no dropped frames in either mode.
Dec 11, 2012, 08:43 PM
Hi Sam234
Going by your initial reports the #20 keychain camera seems like its looking pretty promising so far. If the #20 camera has very minimal or no dropped frames that will definitely be a big plus for making good videos. I read on eBay that the #20 keychain camera supposedly can record videos up to 50 minutes long on 1280x720 (and up to 70 minutes on 640x480). If those video record times prove to hold up that will be great. Also if the manufacture is actively working on firmware updates, thatís another big plus. Hopefully video quality is pretty good with #20 camera. Looking forward to seeing your sample video.
Ray
Dec 12, 2012, 07:28 PM
Tested today in good & moderate lighting I could detect no dropped frames (#15 has 50% dropped under same conditions), at dusk it exhibited about 20% dropped frames (still attached) this rose to close to 60% in very low light conditions when a number of stuck pixels also became apparent.
Video & stills have no aspect ratio distortion, but stills are 4/3 ratio & are cropped v video frame. Still attached was taken in 3MB mode, I have video at same location, but cannot tell how to upload (perhaps I`m too new here). The 2nd image is a snapshot from the video at the same location (timestamp smaller & at extreme edge).
Battery life: The best I`ve had so far is 45mins, normally 40, but that's doing tests under artificial light, may improve under normal lighting. It is definitely better than the #15, I believe the battery is larger.
Dimensions: 32.7x51.5x14.6mm Weight 18 grams.
Dec 12, 2012, 09:19 PM
Hi Sam234
I’m no expert with the 808 cameras or their internal functions, but from what I can see by looking at your #20 camera still photo and the snap shot from #20 video, the picture quality looks pretty good to me.
About battery run time; I think the battery run time may increase slightly after several charge up’s.
About uploading a video, maybe you could try using a video converter from freemake.com (it’s a free and good working converter) and it's located here; http://www.freemake.com/free_video_converter/ . Once your #20 video is converted over you could then try uploading your video to www.youtube.com
I was kind of hoping to see a video from a #20 camera before buying one. I also was wondering how good the #20 video's will be when recording from something that is moving such as a moving car or on an RC airplane. I was wondering about that since I plan to use one on my RC airplane and was hoping the #20 would work pretty good on anything from a cloudy day to a sunny day.
Ray
Dec 13, 2012, 03:29 PM
Just thumbing through...
victapilot's Avatar
Got one today. Focus is not so good, but I might fix that. Vignetting may be due to lens not in the center, we'll see.
#20 Keyfob Camera BSDV0005.MOV (0 min 22 sec)
Same thing in Vimeo
(0 min 21 sec)
Vignetting after reaming and chamfer of lens hole
Dec 13, 2012, 10:19 PM
Hi victapilot,
The #20 video quality looks pretty good so far and it looks to have good potential. When I watched your video, I watched it on the youtube screen using the HD 720p setting and put it on full screen. The video quality actually held up much better than I expected even though I watched it on full screen on my computer monitor.
I also like that the camera seems to be capturing a rather wide view with no noticeable lens distortion from what I could see.
I am kind of wondering how it compares to the 808 #16 camera. I was originally planning on buying the #16 camera until I saw the #20 camera on eBay.
I am also curious about the sound quality of the #20 and if it will record without much static.
From what I can see the #20 camera looks to be pretty promising so far.
Ray
Dec 14, 2012, 08:58 AM
victapilot's Avatar
Ray, I got lucky at Ebay auction and got a good price from Goods-sell for a bare bones model. No extra cables for video out etc. It was shipped from California, received in less than a week. It is a genuine BestDVR #20
The #16 has better firmware, I have one of them. The A lens is similar to the #20.
I'll do more testing of the #20 today
I checked availability today, and don't see any more at auction, and some have inflated shipping cost (mine shipped free), so beware!
Last edited by victapilot; Dec 14, 2012 at 09:28 AM. Reason: Seller was Goods-sell
Dec 14, 2012, 10:39 AM
Video
I won in auction too, not bad price, from BestDVR, only took 10days, I think he has European stock.
I bought the basic thing with just the usb data cable, but you can do powered recordings with that, as long as no data is sent from the port, ie a car usb charger.
Sound is pretty good compared to #15, here's the video.
New 808#20 Key Fob Camera test (0 min 20 sec)
It looses something on youtube, don't know how to make it upload better.
Dec 14, 2012, 04:43 PM
victapilot's Avatar
Here's a re-edited video, used the #20 as a capcam. Vignetting problem is much less now that I enlarged the lens hole.
I do see a lot of color shifting, like the #11. More on that later.
BF109 Pocket Rocket (1 min 40 sec)
Dec 14, 2012, 05:11 PM
victapilot's Avatar
Here's a quick video shows some color oversaturation and instability. Too bad it is short, it was a VERY interesting flight - flew with birds then lost a wing tip, landed the plane, but the camera quit early. Maybe need to cycle the battery, also reformat the card.
#20 Color Shift (0 min 18 sec)
Dec 14, 2012, 05:51 PM
I suppose the trouble is these have to have auto white balance & auto exposure, and its how responsive you make those functions.
Have you tried playing with the exposure setting?
I`m waiting for a spot of decent weather to test this with mine (lots of rain right now).
Dec 14, 2012, 08:20 PM
victapilot's Avatar
Yeah, the #16 white balance can be locked, it is an advantage for AV. Hope the makers of this cam provide that option. I didn't try the exposure setting yet, just removed the date stamp.
Here's a color sample test, compare with others here. Not too bad at all
Dec 15, 2012, 08:19 PM
3d Kiwi
uptime4downtime's Avatar
How does one lock the #16 while balance? That is a very nice feature. This camera looks interesting
Discussion 808 Car Key Micro Camera #16 HD and winter cold yomgui FPV Talk 3 Oct 29, 2012 06:34 PM
Sold Brand new model of 808 # 16 HD Car Key Chain Micro Camera flashted Aircraft - Sailplanes (FS/W) 5 Oct 04, 2012 12:51 AM
Sold Brand new model of 808 # 16 HD Car Key Chain Micro Camera, flashted Aircraft - Electric - Airplanes (FS/W) 3 Oct 02, 2012 07:34 PM
Sold Key fob camera BrightCap232 Non R/C Items (FS/W) 7 Aug 01, 2012 04:17 AM
Discussion Key Fob Camera Breezer1 Multirotor Drone Talk 1 Apr 28, 2012 01:58 PM
