Dec 09, 2012, 11:16 PM
How to fix v911 tail motor
Hey guys
This is my first time on an rc forum, having a read through and the only thing I can find is how to replace tail motor on v911.
I'm not sure if mine needs replacing but the end where the cables go in has come off, I've tried clicking it back into place but it's not working. Not sure how to line it up so that the tail motor works again.
I love this helicopter and it has taken a beating so I would like to fix this. As far as replacing the motor I wouldn't really know how to connect everything up again and my soldering skills are horrid. It would be awesome if I could get some help with this.
Dec 09, 2012, 11:57 PM
Cranky old fart
Balr14's Avatar
Get used to replacing it. They don't last.
Dec 10, 2012, 12:26 AM
Your soldering skills are going to improve if you stick with this hobby =P
One thing i learned about soldering is that if you heat up the wires, it'll soak up the lead right in. The lead actually wraps itself around the hot copper. If you do that to both wires, and then press them together while heating them, up, the lead on both wires melts together like water and you're done in about 2 seconds. Easy. You don't need four arms, just three
Dec 10, 2012, 12:40 AM
Closed Account
And if you were only born with 2 hands and no prehensile tail you can get one of these at walmart, ratshack, etc.
http://www.walmart.com/ip/Grip-55133...469730&veh=cse
Dec 10, 2012, 04:05 PM
bobfa's Avatar
Radio shack sells some conductive glue if you do not like to solder. Buy some 1m heat shrink tubing to cover the wire, or some liquid electrical tape works too. If the wire shorts out you will blow your board. Practice first.
Dec 10, 2012, 04:14 PM
Unregistered User
helipilot23's Avatar
just get a new bnf one
Question how to fix this? cf tube tail boom getmeoutofiraq Hand Launch 9 Jun 23, 2012 02:22 AM
For Sale WTS 50 tail motors for WLToys V911 Wholesale Lot $2.50 pp ESP6918 Non R/C Items (FS/W) 0 Jun 21, 2012 06:16 PM
Discussion fixing mcp tail motor andrewho83 Micro Helis 4 Apr 05, 2012 11:28 AM
Help! How to fix MCPX Tail Motor if end comes off??? ABADGTP Micro Helis 1 Nov 29, 2011 04:12 PM
Discussion How to fix brokwn tail motor wire? mattds Micro Helis 1 Dec 13, 2008 11:33 AM
