Feb 13, 2021, 01:34 PM
I've built two with the standard motor box. I think for the Meridian I only had to replace the blind nuts for the Power 46 with repositioned blind nuts for the Power 60. it's a fairly easy thing to do.
Feb 13, 2021, 02:03 PM
That's great to know as I want as little hassle as possible. It's a pity the power 46 wouldn't fly it without having to add a load of lead to the nose.
Feb 13, 2021, 02:05 PM
I forgot to ask you did you have much trouble getting the old blind nuts out?
Apr 15, 2021, 10:53 PM
I'm having a heck of a time with the wing servos. When my hitec HS425BB are installed with an arm at 16mm length from screw, the arm rubs the side of the slot, isn't centered I've tried different rubber grommets, went into a store and tried every servo I could find, but they all scrape, limiting travel. What does everyone else use for servos? Any chance I got bad servo hatches? Anyone have a working set that could provide measurements of their hatches?
Apr 16, 2021, 08:33 PM
I have a Meridian. What measurement do you want? Here's one from an old Meridian I no longer have. I can see that I had to enlarge the slot a little to prevent rubbing. On my current Meridian. The servo arm is just about centered in the slot., which has not been enlarged. I don't know exactly what servos I am using now. The cover They are standard size Hitec digital servos.
Apr 25, 2021, 08:18 PM
dan culv's Avatar
What is the go-to engine on this plane?
Apr 26, 2021, 01:02 AM
BMFA 190658
SilentPilot's Avatar
Well it recommends the Evo 10 on the box!
Mine has a Saito 91 though
Apr 26, 2021, 04:40 PM
dan culv's Avatar
Evo's are gone.
Apr 27, 2021, 07:39 AM
A man with too many toys
What do these things weigh?
Would my Saito FA-82 be enough power?
Apr 27, 2021, 12:29 PM
BMFA 190658
No idea regarding weight, sorry
The 82 might actually be better suited. The 91 is overkill and probably a bit too heavy!
Apr 28, 2021, 07:53 PM
dan culv's Avatar
saito 100 would probably be perfect.
Apr 29, 2021, 12:51 AM
BMFA 190658
Seriously???
Apr 29, 2021, 09:59 AM
The 100 is a very heavy engine. Much heavier than a 82.
Apr 29, 2021, 10:10 AM
The Meridian does need extra nose weight to balance out.
Apr 29, 2021, 02:21 PM
Thanks, that's good information. Last couple ARF's I built came out nose heavy.
Discussion Hangar 9 P51 Sport 40 ARF SimAndy Fuel Warbirds 46 Sep 25, 2013 09:25 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 11, 2012 10:33 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 17, 2012 12:02 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 11, 2012 10:07 PM
Sold Hangar-9 Twist 60 with JBA-15 Gas Engine - $200 waynemia Aircraft - Fuel - Airplanes (FS/W) 4 Apr 29, 2012 05:05 PM
