Piccolo flys! - Page 15 - RC Groups
Jan 18, 2004, 07:31 PM
CD-ROM Junkie
Art Newland's Avatar
I put an amp meter on the cdrom motor and it's only pulling 3 amps. Looks like it could pull a lot bigger prop, maybe even a Piccolo MR?
Jan 19, 2004, 12:39 AM
Sounds like a perfict EDP50 brushless replacement motor.Rewrap it to 28 turn of 30gage and you have a 3s pack brushless micro heli tail motor replacement and at less weight.Matt
Jan 19, 2004, 03:51 PM
CD-ROM Junkie
Hey Matt,
I stopped by a local computer store and bought a couple of used CDROM's today, one has grey magnets and ball bearings!
Jan 19, 2004, 05:47 PM
Great find,if its about 16grams you can safely pull 12 to 14 amps with a 4x4 prop with that motor.About speed 400 power.Goes great on a 6oz mini wing.About 100mph.Give it a shot.Matt
Jan 19, 2004, 10:33 PM
CD-ROM Junkie
Here we go, home made Piccolo Brushless Power
Gleened a nice CDROM motor today and have started to see if I can convert it for use in my Piccolo. Here are the parts after removing from the drive and removing the old windings.
Jan 19, 2004, 10:37 PM
CD-ROM Junkie
Making a longer shaft
The bearings and motor could be used as-is with a small mount fabricated out of wood, but I need a longer shaft since the power will be transmitted out the bottom to a gear. Here are the parts for the shaft.
Jan 19, 2004, 10:41 PM
CD-ROM Junkie
I had to turn down the bearing tube so as to have a nice fit of the larger tubing. I chucked it up in my drillpress and with a small file, ground it down until I had a snug fit. The smaller tubing fits snuggly into the larger, a 8mm bearing fits perfect into the smaller tube.
Jan 19, 2004, 10:43 PM
CD-ROM Junkie
Assemble tube
I line it all up with the shaft and bearings, and silver soldered it together.
Jan 19, 2004, 10:44 PM
CD-ROM Junkie
I added a little red loctite to the outside of the bearings and put it togther to dry.
Jan 19, 2004, 10:46 PM
CD-ROM Junkie
Here is the shaft assembly from the side.
Jan 19, 2004, 10:47 PM
CD-ROM Junkie
Had to drive out the old short shaft.
Jan 19, 2004, 10:49 PM
CD-ROM Junkie
install the long shaft, which was also removed from the drive, one of the laser guides.
Jan 19, 2004, 10:50 PM
CD-ROM Junkie
I knocked the bell off of the hub! Wasn't to hard to put back on, used some more red loctite.
Jan 19, 2004, 10:52 PM
CD-ROM Junkie
Installed bell, took a while to get it back on straight, the're hardly precision to begin with.
Jan 19, 2004, 10:54 PM
Nice job Art,that should work.Have you come up with a 3mm pinion?Matt
Piccolo Pro Flies! tdriedger Micro Helis 8 Oct 08, 2003 08:53 PM
fun Piccolo flies =) Help I Need more bearings LOL jayboy Electric Heli Talk 4 Jun 08, 2002 10:55 AM
My new piccolo flys great!!! JStory Electric Heli Talk 3 Mar 22, 2002 10:51 PM
My Home-Made CP Piccolo Flys!!!:) Eco8gator Electric Heli Talk 2 Dec 22, 2001 12:52 AM
