Jan 02, 2013, 03:48 PM
Thanks for the recommendations Pat. I think I'll give it a shot.
In the 1:1, the engines are installed with the outboard ones forward of the center one. I toyed with the idea of using a single motor with belt drive to the outboard shafts, but discarded the idea because a) the shaft angles are not parallel, and b) prop walk in reverse would be pretty bad with all three turning in the same direction.
I should have the project under way in the next couple of weeks. Since I doubt that I could exceed your building and documentation skills, I'll spare the group the step by step hull construction process, but plan to start posting once I am ready to install running gear.
Jan 03, 2013, 08:18 AM
pops880's Avatar
great build
nice looken vessel there PAT, like the idea of the pellets for balest looking foward to seeing a vedio of her in the water in action
Dec 06, 2015, 03:59 PM
any ideas on how to improve its turning ability?
Jan 12, 2016, 08:18 PM
Can you tell me where you got the motor from?
Jan 12, 2016, 10:06 PM
P. Tritle's Avatar
Haze, The motor came from RC Hotdeals here:
http://www.rchotdeals.com/products/B...rop-Saver.html
Go with the 930 KV and you'll be in good shape.
PAT
Jan 13, 2016, 05:00 PM
Thanks Pat!
Sep 01, 2016, 10:17 AM
shadow dancer
Is really necessary to "glass" a boat hull? I use three coats of epoxy finishing resin , and never had a problem with leaks or cracks. Your opinions , please.
Sep 01, 2016, 11:35 AM
P. Tritle's Avatar
Shadow, Personally, I won't do another balsa planked hull without fiberglass. Reason being, I did the Jenny Lee without, and within 3 months it was taking on water. But, if going without is working for you, it's best to stick with what works.
PAT
Build Log Dumas 110 ft. Sub Chaser WingRider05 Scale Boats 179 Sep 06, 2015 09:47 PM
Wanted 110 dumas sub chaser kit hampboats Boats (FS/W) 0 Nov 04, 2012 09:13 PM
Video George W. Washburn Tug from Dumas P. Tritle Dock Talk 0 Apr 02, 2012 12:59 PM
Sold LPU-Chris Craft Runabour built from Dumas Kit $190.00 unclegeorge Boats (FS/W) 2 Mar 13, 2012 07:07 PM
dumas bluefin sub gaucho Boats (FS/W) 1 Sep 05, 2004 01:10 AM
