Still using the v911 swashplate and main gear.
I too, have wondered about the offset and may just try it out to see one day. I have posted a YouTube clip link but it is with the moderator. If you do a search for v911 mjx f47 hybrid you should find it. Or www.rchelicopters.info has some more details under mods |
Hi Gents, very nice reading here!!! The only pity is that I didn't found it before I placed the order , but lets come back to the topic. I'm a quite newbie in helis, although I have couple of experiences gained flying an 3CH micro co-ax from CobraToys, then bought a mid-size F-29 from MJX and now fighting with F-47 (of course dissap by the "features" it has. Indeed, some of the questions popped up while reading this thread and I will be pleased if anybody can answer them
1. I got my F-47 from BangGood (of course), but you mentioned some clones coming from there - should I understand that they are not shipping an originals from MJX and those are only replicas, cheap crap clones with maybe few orig. parts? 2. Is it normal that the F47 is a bit deflected from the vertical axis while hovering? (when I look from behind its to the right side). Is it a standard by single rotor FP? 3. Even I have a new Brush-less version (main rotor) I also noticed some general issues with the tail rotor (think will went down soon), but I read elsewhere that it might be worth to replace the tail with a spare from v911 (performs better and lasts longer). Do you think it makes sense + equip it with Alu cooler or replace with another brushless if possible? (what about balancing/controlling it?) 4. Regarding the "feature" while rotating to the right, it goes forward / left=backward - can be it a connection to the point 2. deflection/misalignment? I don't think it can be fixed simply by shifting a battery, but are there any further available methods? Flashing CB, replacing parts or fixing tail/balance? Is it worth the time and money? Any of your feedback will be highly appreciated |
every single rotor tilts toward left when flies because tail prop when counteracts rotation of heli caused by main rotor pushes it to the left. let's rephrase it: tail motor has function to prevent heli's rotation to the right (caused by main rotor) and it pushes it to the left. so even real life helis fly like they are pushed from right to left. these small helis don't fly as smoothly as big cp helis so if it hovers and listens to command I don't think you need to bother. |
Hi asanovrus, thanks for your quick expl. this is of course clear. But how can I fly in circles with F47 if it does these tricks? OK, the clockwise side I can imagine, it is possible even with lot of adjustments (while turning right it goes also forward), but the counterclockwise is fully impossible - if I want go left forward, it simply stops, as at the same time it want go back.
Hopefully I am clear enough (it was also mentioned above in the post from Manyb or #62B by Buphilo) @GuardianLegend: I had also a problem with strange RIGHT servo behavior when I did a full throttle or full pitch -> the problem was on the CB right at the servo 5 pin connector = rubbish Chinese work (short-circuited pins) so with a small knife I carefully splitted each from another and BINGO! it works well (no servo resets). @fauconnier: could be the sliding related to the servo performance (self-compensation)? I realized that the right servo (pitch) is not 100% performing and much slower then the left one (roll). Could it be that the swashplate isn't properly adjusted to the problematic servo performance, thus giving us the sliding effect? Thanks to any reply. |
Gentlemen of F47 persuasion:
I just wanted to share with you a procedure that has made my F47 really perk up in terms of responsiveness in flight. It is so much more of a pleasure to fly now. BTW, I fly in the highest rate setting with the elevator digitally trimmed for fast forward flight, (about 50%) on the stock Tx. I removed the .9g flybar weights from each end of the flybar and replaced them with the .6g weights from a V911pro. Its flies so much better with instant response from servo action now, unlike the sleepy laggy way it reacted before the change out. I will next try the .3g weights from a V911 and see what results. Best to all. |
randycastell >thank you for your return
I changed an other motor tail, and nothing, it spinning slowly, and more fast with time. What are the symptoms of a gyroscope hs ? Last attempt, I ordered a rear tail motor walkera mini cp. It seems that it's adaptable. If it does not work, I hesitate to take another F47 but brushless, and the other I use the room. I change or outright brand and model. |
Good luck, I hope you are successful in your repair. |
Sorry, i repost here :
I changed my mother board and the tail motor, and son. But the first test, to start having jerks, and it is part of a whirlwind. I lost the rear arm. This morning, I reseal everything and put the glue on the rear arm. It takes off well, but in jerks and turns himself in every jolt. As a second hand of a watch. |
Thread Tools | |
Similar Threads | |||||
Discussion | MJX F47 - baby brother to the F45 | gordonzo | Micro Helis | 110 | May 01, 2014 09:22 AM |
Mini-Review | The RC EYE One Review ***Updated: Short flight video! *** | jameschen072 | Mini Multirotor Drones | 195 | Aug 06, 2013 08:45 AM |
Discussion | MJX X100 Review ***Updated: Video*** | jameschen072 | Mini Multirotor Drones | 143 | May 02, 2013 10:34 PM |
Mini-Review | Walkera CB100 Review with pictures and video coming soon | Tom Z | Micro Helis | 46 | Jul 24, 2010 10:42 AM |
