I remember someone actually measured the real resolution of servos. Very good servos had a precision of 2 µs, and normal servos about 4 µs.
4 µs is equivalent to (2ms - 1ms)/250 steps, or 8 bits.(256 steps) 2 µs is equivalent to (2ms - 1ms)/500 steps, or 9 bits.(512 steps) 1 µs is equivalent to (2ms - 1ms)/1000 steps, or 10 bits (1024 steps) So 8 bits is acceptable (like DL), 9 bits is excellent, and above is still better but probably overkill (OpenLRS etc). |
Hi kha, DTF UHF and flipflap
I appreciate you guys getting back to me. @ DTF UHF: Are you saying that FrSky samples three times the rate that Orange Open LRS does? Cheers Jase |
Hi Gang
Just a couple of questions about obtaining RSSI.
Cheers Jase |
For the RC filter, enter your desired values for the resistor and capacitor into this equation: 1/(2*pi*R*C) If the resulting value (the cutoff frequency) is between 1 and 500 (and the R&C values are reasonably close to those provided by kha) you will be fine. The capacitor does not need to be electrolytic. That diagram does depict the circuit you need. |
Thanks for getting back to me. My electronic knowledge is basic so I'm having trouble following your explanation. At this point I understand that Orange Open LRS has a resolution 1024 while FrSky is 3072. I suppose I simply wanted to know would I notice a difference? I am however keen to further my understanding. Are you saying that both systems are 10-bit but because FrSky samples more frequently the resolution is greater? As for the RC Filter, what are my desired values? What type of filter is this eg high pass, low pass? Cutoff frequency? =1/(2x3.142x10x10) =1/628.4 =0.00159134 *This is not between 1 and 500. I'm not sure what's going on here? Cheers Jase |
Unfortunately I don't know how the FrSky system samples and transmits its data, I was simply interpreting what another user said on a different forum. Unless FrSky releases information about their systems, I'm not sure that anyone can come to conclusions about how their system handles data.
The values you put into that equation need to be in ohms and farads, so 10k = 10000 and 10uF = 0.00001 which will give a cutoff frequency of about 1.6Hz. |
Hi DTF UHF
I was wondering about k and µF. So I assume a cutoff frequency of 1.6Hz is good (between 1-500)? I'd love to know what's happening here i.e. the significance of this calculation? As always really appreciate the help. Cheers Jase |
Sure thing. A resistor and capacitor in that configuration makes a lowpass filter. This can be interpreted as an averaging filter. Imagine the capacitor as a bucket that holds voltage, and the incoming system as a hose that is switched on and off quickly. The bucket will hold a small amount of water that smooths the pulses of water into a steady flow. If the pulses are on for a longer time the output from the bucket will be a flow of a larger amount of water. If the pulses are very short, the flow will be very small. The steady flow is the 0-3.3V signal, and the pulses are the high-frequency PWM which only has values of either 0 or 3.3V.
The size of the capacitor is the size of the bucket. Smaller buckets won't be able to smooth the pulses so the output will also have some pulses in it. Buckets that are too large will average the pulses over a longer time period so the output will lag behind the input significantly. If you are interested in learning more about how such systems work, I highly recommend this book: http://www.amazon.com/Cartoon-Guide-.../dp/0062731009 it really is a good introduction to physics and basic electrical systems (which are both related through nature) and is appropriate for almost all ages |
Hi DTF UHF
I love the book . I'm really interested in learning about electronics. I've recently attended an introductory hobby course where we made a regulated power supply. Unfortunately, there wasn't much in the way of theory which I was mainly interested in. Grasping key concepts in crucial in building knowledge. I suppose it's a little like foundations of a house. So would your preference be a 10µF or a 100µF capacitor? From your explanation (which was awesome) the 10µF may make the RSSI jumpy while the 100µF may make it sluggish. Cheers Jase |
I have a problem when activating telemetry. Despite what baudrate 0,1 or 2 I am running my servo jitters like crazy when telemetry is active. When I disable telemetry the symptom disapears. I am running openlrsng 3.0
Hi Gang
Well I've been busy. I've put together the following;
I really want to thank everyone for their help. I apologise for the poor video. It's been really wet here and my video system doesn't like it. Cheers Jase
Thread Tools | |
Similar Threads | |||||
Wanted | Anyone got a good 433mhz UHF RX Antenna? | wamdue | FPV Equipment (FS/W) | 4 | Nov 18, 2016 04:06 AM |
Question | 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? | Kahnx | FPV Equipment | 11 | Dec 23, 2013 10:19 AM |
For Sale | Chainlink UHF system + few matching Rx's | i3dm | FPV Equipment (FS/W) | 0 | Apr 22, 2012 06:58 AM |
Discussion | stiff antenna for 433Mhz UHF Rx ? | i3dm | FPV Talk | 14 | Feb 17, 2012 02:25 PM |
Sold | HK "Orange" Satellite for HK "Orange" Rx | rikybob | Aircraft - General - Radio Equipment (FS/W) | 1 | Jan 29, 2011 04:19 PM |
