Nov 27, 2012, 05:18 PM
Bixler 2 questions?
I am buying a Bixler 2 for use with FPV. I own a immersion 5.8 600Mw tx and a Fat Shark camera. I also own a Immersion EZOSD. I need to know the best quality metal gear servos that will work and fit the Bixler 2. I also want flaps. I need to know how many servos total along with wiring and connectors to make it all work. I have a 9x radio converted to a FriSky system and a 4 channel RX for the frisky. I wish to order everything I will need in one order. I am sure someone out there has gone through all this before and can give me a complete list of what to order. THANKS!
Nov 27, 2012, 06:03 PM
Reduce the drama...
rick.benjamin's Avatar
https://store.diydrones.com/
Nov 27, 2012, 07:35 PM
hjukhjuk
gooby's Avatar
Use 4 Hitec servos if you want quality with two extension wires and a servo reverser. I'm using the cheap hobbyking servos with my Bixler 2 and they work just fine. Your immersionrc FPV components should be plug-and-play with nothing extra needed.
Nov 27, 2012, 07:40 PM
Is the Bixler 2 better than the Bixler 1 for fpv?
Nov 27, 2012, 08:23 PM
hjukhjuk
gooby's Avatar
The Bixler 2 does have an advantage with it's larger wing area and flaps, but the small interior space is a problem. For anything more than a very basic FPV setup (what I have) I would get the Bixler 1.1 because it allows you to move a battery anywhere you want. The space inside is much bigger because you don't have the screw tubes or bumps on the floor (the bumps in the bixler 2 make it impossible to use a big battery without weakening the airframe).
Poll Bixler vs Bixler 2 which one will you buy? rcmaverick Electric Plane Talk 18 May 01, 2015 09:55 PM
Discussion Airfoil data for Bixler / Bixler 2 Airplanes StrikeEagleIII Electric Plane Talk 7 Nov 14, 2012 07:38 AM
Question Question to Bixler 2 users.. jsxx FPV Talk 4 Nov 01, 2012 03:46 PM
Question Hobby King Bixler 2 Night Flying Questions adza Foamies (Kits) 8 Oct 27, 2012 07:18 PM
Discussion Bixler Prop question (newbie!) MadridFlyer Parkflyers 9 Apr 24, 2012 10:05 PM
