Nov 25, 2012, 09:24 PM
3 Blades is Better Than 2!
kman24's Avatar
New Product
Dynam Tiger Moth
Not too much information out on this one other than a sneak peak from NP...
New Dynam Tiger Moth Bi-Plane Review (11 min 18 sec)
Kman
Nov 25, 2012, 10:37 PM
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Seems to go fairly well and looks good.
Nov 25, 2012, 11:44 PM
Fly Low - Hit Hard
Red Flyer's Avatar
interesting...
sub'd
RF
Nov 26, 2012, 05:00 AM
Parkstormer!
Subscribed!
Nov 26, 2012, 05:10 AM
Likewise
Nov 26, 2012, 06:41 AM
Supersonic Engineering
GordonTarling's Avatar
Looks nice, but needs some colour other than yellow on it. Easily done though.
Nov 26, 2012, 10:23 AM
Taranis Tyro...
MattyB's Avatar
Wow, very nice! Something about the undercarriage looks not quite right to me (wheels too small, or maybe gear not swept forward enough?), but other than that it seems a good scale representation with excellent flying characteristics. I would prefer if it was 3S powered, but I guess bipes do have a lot more drag; given how over-powered it seems on 4S I suspect it may be possible to fly it in a scale manner on a 3S pack (might need a higher Kv motor though).
All in all I am excited - the Tiger is one of my favourites ever since I was bought a flight in the real thing a few years ago, but most of the kits available have had issues which I couldn't look past (ArtTech and GWS too small and not scale enough, HK lots of production issues, Green Models no longer available etc etc). I can't wait til this is available in the UK!
Nov 26, 2012, 04:45 PM
Something to compare it to. At first clance it looks good to me. Stop video at 1.44. Change the serial number and instant RNZAF plane!
Description:
1/7th scale
Nov 26, 2012, 06:06 PM
Taranis Tyro...
MattyB's Avatar
Just found some basic specs on the Dynam website...
  • Wingspan: 1270mm (50in)
  • Overall Length: 1050mm (41.3in)
  • Wing Loading: 41g/dm2
  • Servo: 9gx4pcs
  • Battery: 14.8V 2200mAh Li-Po, 25C
  • Speed Controller: 40A Brushless
  • Motor Size: BM3720A-KV650 Brushless Outrunner
  • Flying Weight: 1450g (51.2oz)
Nov 26, 2012, 06:12 PM
kman24's Avatar
Wow, I am surprised that they used the 650kv motor. That is the same motor they use in all their 3D planes. No wonder this plane had good vertical in NP's video.
Kman
Nov 26, 2012, 07:04 PM
Taranis Tyro...
MattyB's Avatar
Agreed, it's a very low Kv for a plane where even the full size has a two blade prop. At such a low w/l (~13oz ft2) it should be possible to work out a 3S powertrain though.
Nov 26, 2012, 08:03 PM
kman24's Avatar
The newer Dynam WWII Warbirds all have a 500kv motor in them meant to run on 4s batteries. They all have big 13" props on them, though. All the newer Dynam planes that have been release this year are designed to run on 4s. It helps keep the amperages down on these power systems and allows them to run cooler IMO.
Kman
Nov 27, 2012, 11:15 AM
Taranis Tyro...
MattyB's Avatar
Good points - I can see that higher voltage, lower amp systems are more efficient way to generate the power overall. It will be interesting to see what prop they go with and how that affects the wattmeter readings, but with so much wing area it really shouldn't need a lot of watts for scale flying - it may be that 3S is fine without any other powertrain changes.
Nov 27, 2012, 11:26 AM
kman24's Avatar
I know that people have flown the Dynam Peaks 3D Bipe on 3s successfully with the same motor. They just didn't have unlimited vertical with it like on 4s
So, I am sure you could fly this plane on 3s as long as the prop was sized accordingly.
Kman
Nov 27, 2012, 04:53 PM
Well the plane is flying out of it's skin at the moment , that's for sure, and to be 'scale' the prop could perhaps be smaller. Yes,thats right, SMALLER ! Unbelievable.
Description:
Description: Name: 2012112611419.jpg
Description: Name: 201211261183.jpg
Description:
If you could get away with a smaller prop that would give more options ??
Not sure about those wing struts ? Perhaps the top wing is a bit big or the bottom wing a bit small.Yet it looks really good here.
Description:
All things considered it doesn't look too bad does it ?
Wanted Tiger Moth ARF or kit, 40" to 50" span sammy Aircraft - Electric - Airplanes (FS/W) 7 May 19, 2013 07:21 PM
For Sale GP Tiger Moth arf fgroza Aircraft - Electric - Airplanes (FS/W) 1 May 15, 2012 12:08 PM
Sold GP Tiger moth fgroza Aircraft - Fuel - Airplanes (FS/W) 0 Mar 06, 2012 02:10 PM
Discussion Help, im building a GWS tiger moth 400 and lost the manual jaas75 Parkflyers 4 Feb 28, 2012 07:19 AM
