Nov 22, 2012, 07:10 AM
Parkflyer Extraordinaire
FltLtBiggles's Avatar
New Product
Hobbyking Sonic 64 Wing EPO 1230mm
Just spotted this http://www.hobbyking.com/hobbyking/s...30mm_PNF_.html on HK's website - looks to be a pretty good flying wing.
Flying video here http://www.youtube.com/watch?feature...=Sr-mW-jKCKQ#!
The only flying wing I currently own is the radjet which is very close to early retirement. Would this be a good second flying wing?
Latest blog entry: My first blog post
Nov 22, 2012, 09:37 PM
OD123ify Snake
Morodie's Avatar
Yes this thing is great,it was our first edfOurs is a Neptune but its the same bird.
I think this is the best buy.http://www.nitroplanes.com/02a-101-n...ith-motor.html
But it flys great,no balance trouble either.
Tech One Neptune New Flying Field (6 min 7 sec)
https://www.youtube.com/user/OD123ify?feature=mhee
Nov 22, 2012, 09:51 PM
A4Framie
alfiev's Avatar
Got one on the way. Never had a "flying wing" so should be interesting.
Alfiev
Nov 30, 2012, 02:53 AM
To Have & To Hold
Percivale's Avatar
Okay I am going for it hope I can launch if side-arm style.
Dec 16, 2012, 05:43 AM
I just bought this plane, and he had the same problem with neptune, the esc are easy to heat, but other than esc problem, the plane was very nice
Dec 21, 2012, 02:05 AM
A4Framie
alfiev's Avatar
So, I just returned from a trip away to visit family, my new Sonic was waiting for me on the doorstep. Looks good, fairly easy to assemble, I am using UHU POR for assembly. Could possibly test-fly on Sunday, but the weather here is really unsettled.
More to come.
Dec 22, 2012, 11:45 PM
A4Framie
alfiev's Avatar
And the weather played the game today so I got to fly her a few times. Had never flown delta wing with elevons and have to say this was pretty easy to fly. A small amount of trim and she was steady as. Agile and fast enough for me, but quite good to fly at low speeds as well. Landing is a power off long glide and a slide. No worries.
Good fun, sure to take it with me every time I go to the field!!
AlfieV
Dec 22, 2012, 11:49 PM
TheLeabres's Avatar
Can you tell me if the wing is one piece or is it like the Skyfun where you glue two outer wing parts to the fuselage? Thanks.
Dec 23, 2012, 02:25 AM
A4Framie
alfiev's Avatar
Hi there,
the wings are in two parts with a carbon fibre tube passing through the fuselage and into each wing half. Pretty easy to put together.
Alf
Jan 26, 2013, 05:07 PM
H ello all
I want one wing, but well for now budget is low...so would like to ask if someone can send me plans of this model, or even a draw with sizes and measures, so i can build my own thanks all for the help.
Regards
Mar 12, 2013, 08:45 PM
Are you still interested in dimensions?
Apr 30, 2013, 08:30 PM
Sparky "Electrics Rule"
bobf's Avatar
Can u use 4 cell pack in stock setup
Apr 30, 2013, 09:58 PM
No. Need to have higher capacity ESC and would also need to relocate the ESC outside of the compartment as there isn't much space. Fairly easily done.
May 01, 2013, 01:09 PM
bobf's Avatar
I thought the stock esc even gets hot on three cells. Would not 4 cell push it harder. Is the stock motor safe on 4 cells.
Are you saying the upgraded escwould not fit inside or that even the stock esc should be mounted outside which would really distroy the great looks.
I am looking at going stock to start and see how it goes, Just want to know if I can ungrade later if I want more speed
Thanks every much for your input.
Sep 02, 2014, 03:00 AM
Any good speed increases going to a 4S?
Wanted Hobbyking Bixler EPO 1400mm saltydog56 Aircraft - Electric - Airplanes (FS/W) 4 Jun 07, 2012 04:21 PM
Mini-Review Hobbyking Stinger 64 tdogg77 Foamy EDFs 1 Apr 28, 2012 10:21 PM
Video Hobbyking 1400mm Mustang EPO Lanyu aerobatics mopetista Electric Plane Talk 0 Apr 07, 2012 10:47 AM
For Sale Hobbyking Radjet 800 EPO 800mm (PNF) - LPU - Orange County, CA Triptykon Aircraft - Electric - Airplanes (FS/W) 4 Mar 20, 2012 04:56 PM
Sold LAX LPU: HobbyKing EDF Fighter Jet 70mm EPO RTF $80.00 Mikey 68 Aircraft - Electric - Jets (FS/W) 2 Mar 07, 2012 02:55 PM
