Durable Aircraft Models (Unobtainium) 66" P-51 - Page 2 - RC Groups
Nov 17, 2012, 09:39 PM
Dick J's Avatar
Rubio
I think I speak for all the guys out here that hate to build !! You inspire me !! so I got to work on a couple things that I also like !!!!
Nov 17, 2012, 09:43 PM
Nothing to see here...
67econoline's Avatar
My Friend ,
You really are one of priceless few...
Rubio
who loves his work
Nov 17, 2012, 09:52 PM
Dick J's Avatar
He he he Thanks my friend, we have to fly again soon !!!!!!
Nov 18, 2012, 01:07 AM
It's not going to build itself
TRISME's Avatar
Go Rubio!
Tom
who understands how special a DAM kit is
Nov 18, 2012, 12:31 PM
Next lets install the spars and check the line up.
Description:
It's a little off.
Description:
I sanded keeping my shape till it looked good.
The spar channel is deeper at the root than at the tip.
Look at the spar and you can see the change in size.
Description:
Here is the final wing shape.
Description:
Description:
The same treatment to the other side.
I tape my wing beds together to keep them where I need them.
Rubio
Nov 18, 2012, 12:58 PM
TRISME's Avatar
You can plane down the spar a little, to get it under the suface of the channel and cap it with epp scraps, or just glue it in and sand it off the top and spackle. I've done both.
Tom
so stoked with your build log
Nov 18, 2012, 01:09 PM
Thanks Tom
The spar is below at the tip.
But at the joint and the root it is almost even. I think i will sand it a little and cap it with a some foam. Or at least that is the current plan.
Rubio
Nov 18, 2012, 01:15 PM
Next we are going to make a sander or the spinner. Wade gives you a sanding block made from EPP. All that is needed is to finish it off.
Description:
A little super 77
Description:
Spray the block and the paper
Let dry then add a light mist for extra sticky.
Then apply.
Description:
Rubio
Who is off to go running
Nov 18, 2012, 03:22 PM
While I cooled down from my run. I checked on the primer on my P-51.
The grabbed the sanding block.
Wade marked the back the the size and put it into quadrants. I marked them 1 to 4. The started to sand it to shape after about 10 minutes if light sanding I took it from this .
Description:
To a spinner.
Description:
Wades method
Description:
It worked quite well!!!
Rubio
Who is makin breakfast
and heading to a slope!!
Nov 18, 2012, 03:32 PM
Man I'm almost done!!
Description:
Rubio
Nov 18, 2012, 04:53 PM
Good for what ALES you
awilmunder's Avatar
Hi Rubio,
I picked up a partially built DAM P-51 at a club auction a few weeks ago and just got the manual on Thursday. Looks like I have all the key pieces except the ailerons.
It appears that the fuse was coated with what may be a thin layer of epoxy. The servos are sealed inside and I'll need to cut open a hatch or two to see what is going on electrically.
This was going to be about #3 on my project list, but I may decide to bump it up so we can compare build notes.
--Aric
Nov 18, 2012, 07:53 PM
Hi Aric
I would like that very much,
if you can post some pics of where it is at in the build. We can have some fun and make a great flyin plane go airborne!!
Lets face it until we give them life with the build they are just some foam and wood.
It's up to us to take that and make Flyin Machines!!!
Rubio
Nov 18, 2012, 10:48 PM
i will bump this dam p51 up the build que also
and finish it so i can fly the dam thing but not break
it before the dam cajon fest
steve
Description:
Description:
Nov 18, 2012, 10:54 PM
TRISME's Avatar
Go Steve Go!
Cool alien eyes dog too!
Nov 19, 2012, 01:37 AM
awilmunder's Avatar
Here are some photos.... My first project is to open up the two fuselage hatches (sealed by epoxy? coating) and determine the wiring. The exposed connectors are old-style Airtronics and so these will need to be rewired since I run Spectrum RXs. The rudder and elevator servos are sealed and will need push-rods connected.
The tape applied to the wings is probably 10 years old and the adhesive is dried out. Gently pulling the tape removes the pieces. I haven't used this tape method and it clearly has a limited lifetime so I want to consider what options I have here.
Discussion Phoenix Models Super Decathlon ARF .46-.51,66" rc_man1 Glow to Electric Conversions 10 Jun 15, 2013 02:25 AM
For Sale cassini aero models usa p 51 mustang 120 arf asteroidguy Aircraft - Fuel - Airplanes (FS/W) 0 Feb 22, 2012 01:14 PM
Sold NIB EPP Durable Aircraft Models (D.A.M.) 66" P-51 Mustang codezilla Aircraft - Sailplanes (FS/W) 6 Jul 27, 2010 06:21 PM
Sold Durable Aircraft Models P-51 Mustang DAM dtd24 Aircraft - Sailplanes (FS/W) 9 Apr 04, 2008 09:45 PM
Sold Durable Aircraft Models P-51D - Los Angeles area local sale SchiessCo Aircraft - Sailplanes (FS/W) 1 Jun 01, 2007 11:58 PM
