View Poll Results: What applications would you use balancing for?
helicopters 3 11.11%
Turbines 4 14.81%
Electric Ducted Fans 24 88.89%
Drones 3 11.11%
Aircraft Props 12 44.44%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
Oct 31, 2017, 01:13 PM
Crash 'em if you got 'em
waytooslow's Avatar
Originally Posted by dynexhobby
New laser sensor module available. This is a direct substitute for the ir sensor. See http://dynexhobby.ashop.me/p/9280515...or-module.html
*Note the sensor may not work directly with the Vortex. The Vortex has a lower power supply to the ir sensor. If you wish to use it on the Vortex you will need to bootstrap the 5v power pin to the laser sensor.
Can you explain the bootstrap? or a quick schematic?
Nov 01, 2017, 08:57 PM
Good vibrations.
dynexhobby's Avatar
Sure, in the attached image (sorry its an old image), connect the red wire from the Laser module to the center pin of ACC2. Hope that helps.
Dec 27, 2017, 02:17 AM
Good vibrations.
dynexhobby's Avatar
Dear Drone Users,
Our AirTune software has been updated to perform simple 2 blade balancing.
enjoy!
Jun 13, 2018, 04:21 AM
Good vibrations.
dynexhobby's Avatar
Dear Friends,
We have just finished updating our Platinum software. The latest version now includes full functionality for balancing turbines. A lot of guesswork has been automated and you can now calibrate your test rig once and then use that data to run balancing on multiple rotors. The new code is located under the "Jet" button.
In addition, we are also working on a complete balancing system that will include a professionally manufactured balance rig. Watch this space!
Download the latest version here: http://www.dynexhobby.com/software/dynexhobby.zip
Enjoy!
Jun 13, 2018, 08:42 PM
Multifaceted Heli Nut
heli-headcase's Avatar
Thank you!
Jun 26, 2018, 05:43 PM
I just bought the Impulse balancer. Can anyone tell me what to use for balancing weight for the EDF fans? What do you use and how do you attach the weight?
Jun 26, 2018, 07:30 PM
Good vibrations.
dynexhobby's Avatar
You can use epoxy putty. Mix it, apply it like a putty and shave weight off until you have the right balance. When it cures it will bond to the EDF surface. Only apply it to the inside of the center hub so it doesn't fling outward.
Jun 27, 2018, 09:17 AM
Sorry not an expert but can one use a self tapping screw instead?
Jun 27, 2018, 11:33 AM
I use aluminum duct tape on the inside of the impeller hub. Attach it in such way that centrifugal force would press it in even more.
Have ~100 hours of cumulative run time on 2 Eflite fans. Still holding on strong.
Jun 29, 2018, 05:44 AM
bps
bps
bps's Avatar
I would not use anything that puts holes in the rotor. Tape or glue applied to the inside of the rotor hub or spinner makes the most since. Like others have posted centrifugal force keeps the balance weight firmly attached.
Aug 07, 2019, 10:00 PM
Good vibrations.
dynexhobby's Avatar
EDF Balancing Cradle
Dear friends,
After some time developing balancing solutions, DH are proud to release the Newton Balancing Cradle. The Newton can be used for turbine and EDF setups.
Please check it out at https://dynexhobby.com/index.html
regards
DH
Nov 17, 2019, 01:38 AM
Good vibrations.
dynexhobby's Avatar
A new software update is available, Version 5.4. This version has a bug fix for the RPM meter. It also includes a new live analysis tool for single plane balancing. The single plane balancing tool allows users to configure their setup once and then run multiple balancing with a single click of a button. Note: This only works for rotors of the same configuration and build standard. Enjoy!
Question EDF Impeller Balance old_dude Electric Ducted Fan Jet Talk 8 Nov 16, 2012 05:24 AM
For Sale Optical EDF Balancer for sale yakhakker Aircraft - Electric - Jets (FS/W) 2 Jul 29, 2012 12:16 PM
Sold Pair of balanced Wicked 4800 motor and matching ESC for twin EDF setup The Don Aircraft - Electric - Jets (FS/W) 4 Jun 25, 2012 07:34 PM
Discussion EDF fan balancing Mike873 Electric Ducted Fan Jet Talk 7 Apr 24, 2012 07:29 PM
Sold Exceed-RC stock 70mm EDF/Motor (balanced!!).......30 shipped RC_Bob Aircraft - Electric - Jets (FS/W) 2 Mar 26, 2012 11:46 AM
