Nov 12, 2012, 03:34 PM
FrSky FASST RX RSSI
Hi guys, have seen a lot about getting RSSI from FrSky rx's, specifically there own modulation Rx's, but nothing on their FASST compatible ones.
I have put this circuit down which I found online, does anyone know if it will work for say the TFR8, or the TFR8 SB? Anything with a frequency based output should theoretically work, but does the TFR8 have a frequency based (packet data) LED?
Cheers
Nov 12, 2012, 03:51 PM
also my time constant 1.1RC seems high at 0.748 secs. What is a suitable time constant for a RSSI buffer?
Nov 12, 2012, 06:54 PM
1fullbird's Avatar
Cheers
I asked a similar question. According to Penpen it should work.
https://www.rcgroups.com/forums/show....php?t=1768160
Nov 12, 2012, 09:31 PM
AFAIK, the LED of the FrSky TF series Rx is blinking in the same way of their V8 series and Two-Way series.
So the RSSI convert might work as well.
Nov 13, 2012, 04:27 AM
I use the orange receiver.
It works. But if you lose the signal link completely, the red led blinks on – off – on – off which causes the filtered voltage to jump up and down…
I used the values for the resistor and the cap from the tutorial of rcexplorer. Are there any better values for the components?
Nov 14, 2012, 04:50 AM
If I build a few and test some different time constants would anyone else want one. Is there much call for these LED-buffer RSSI devices. Could always sell them on ebay.
Mar 09, 2015, 06:45 AM
Does this really work with the Frsky TFR8 SB?
I got another scheme as in the picture below but I havent tried anyone yet, jusr want to be sure it works first?
Here is the link:
http://fpvlab.com/forums/showthread....935-FrSky-RSSI
Mar 09, 2015, 10:12 AM
A man with too many toys
Here is the link:
The guys at 3D Robotics recommend a 10uf capacitor and a 4.7k resister. I have been using that for several years. It’s simple and it works. http://plane.ardupilot.com/wiki/comm...th-indication/
I have tried lower resistor values but it never gets to 100%. Slightly higher values work but response is slower. I think that 4.7k is close to the optimum value.
Mar 09, 2015, 12:30 PM
Thanks man,
I hope it works with Frsky Futaba FASST rx (TFR8-SB) also?
That page shows a Frsky D8R-XP but maybe its the same solution and same components?
Sold SOLD FrSky TFR6 FASST compatible RX's / Futaba 7C 2.4G TX fizzwater2 Aircraft - General - Radio Equipment (FS/W) 6 Aug 15, 2012 10:21 AM
Sold FrSky TFR6 FASST Compatible 7CH RX's Alex Schauer Aircraft - General - Radio Equipment (FS/W) 8 May 02, 2012 03:39 PM
For Sale FrSky 7ch Futaba FASST Compatible RX NIP Alex Schauer Aircraft - General - Radio Equipment (FS/W) 2 Apr 30, 2012 10:17 AM
Wanted anyone wth a Frsky RX that has the RSSI out to OSD mod/s already installed for sale? TheSelf FPV Equipment (FS/W) 2 Mar 11, 2012 09:11 PM
Discussion Rssi pin on futaba FASST rx JohnyGab FPV Talk 4 Mar 18, 2009 12:43 PM
