Question
Turnigy 9x convert to 72mhz?
I just ordered a 9x and I would like to be able to convert it to MHZ so I can use it with model submarines, as well as 2.4 applications like planes and boats. I use both 2.4 and MHZ bands
Can anyone give me some insight on doing this? i would need a mhz module and? I dont have it yet so i can examine it Thanks! |
JR modules will fit, but you have to make some minor changes in the radio. They have one pin grounded that in some older JR modules expect to see 6 volts.
There was a mod posted that showed how to add a 6 volt regulator. I will look for the link. I will double check, but pretty sure the JR synth module does not expect the 6 volts and simply isolating the pin is enough. If you do isolate the pin then you have to redo the connection in the original 2.4 module should you ever want to use it. You will also have to do something about the antenna Older 9X radios bought from other vendors still had it, but those bought from HK never did. Pat MacKenzie |
Link to 6 volt mod
http://www.netalbum.org/FlySky-EURGL...EN_gall_73.php My post about isolating the grounded pin and adding the jumper to the module. This radio had the built in 72mhz antenna. https://www.rcgroups.com/forums/show...postcount=5588 Note that the module mod is only required if you want to use it in a JR tx. To use it in the 9X you don't need any mod to the module. Pat MacKenzie |
Thanks Pat. Cool, I would love to be able to use a JR synth module on this radio.
i would really appreciate the link! Definately am gong to do this mod. Rick |
links posted above.
Awesome, thanks!
I am running the JR 72 MHz synth module in a 9x with no mods to the the 9x at all, except the antenna mount itself, which I had to make with a little piece of bent metal soldered to the board with a screw sticking through it for the antenna to screw on.
So just to repeat, there are no 6V mods needed on the 9x if you use the JR synth module only. EDIT: I am running a 3S battery, not a 2S... I don't know if the lower voltage would require any changes. 2nd EDIT: you must use PPM mode only... PCM is proprietary to JR and your 9x knows nothing about the signals required by the transmitter or receivers. |
I did try my synth module (before I even upgraded the 9X firmware) and it worked fine.
But isolating the pin is easy, and you never know if someone might try a module that could be damaged. Pat MacKenzie |
It doesn't matter much now except that someone might have an old one with the antenna and wonder. By the way, mine is still going strong with an FrSky DHT module, Smartieparts programmer and ER9x firmware. I've had three more 9x transmitters (2 FlySky and one Turnigy) since then (for myself and other people) and all have worked perfectly. |
The particular flavor of PCM was proprietary to FlySky and didn't work with JR. I assume they were discontinued a couple of years ago. |
I have a 9303. I like the cheap Turnigy because I get the transmitter wet with my boat and sub testing. I drip water on it, touch it with glue on my hands etc An expensive radio is not good for what I do. Its like doing construction and driving a brand new BMW loaded with tools, Ha This is great to hear, no mods minus the antenna Im am def going to run a 3s lipo |
where can I get a 72mhz module for my er9x?
I assume you mean for your Turnigy 9x (or FlySky 9x) . The type of firmware does not affect the use of FM.
Unfortunately, the FlySky FM modules are no longer manufactured, so you would have to look for a used one. Other labels include IMax, Eurgle. As discussed above, it is also possible to use a JR synth module but only on PPM for 8 channels. Again, you would probably need to look for a used one. Either way, you would need to rig an antenna mount (unless you have a 9X from 2010 or before). |
Why would he need a synth module to operate a sub ? He can get a used fixed frequency module for under $20.
Heck they even sell new modules 'Futaba slot' for $2.99 http://www.servocity.com/html/hitec_air_modules.html |
Thread Tools | |
Similar Threads | |||||
Question | Turnigy 9X V2 2.4Ghz or Dynam NE-KO 4 72mhz | Onelink | FPV Talk | 4 | Jun 23, 2011 10:44 AM |
Question | Can you convert Turnigy 9x transmitter to nicads? | flying jeep | Radios | 5 | Jan 16, 2011 08:54 PM |
Discussion | How can convert simcable E-sky to turnigy 9x(JR port) | NiceOh | DIY Electronics | 4 | Nov 17, 2010 01:31 AM |
Help! | How can I to convert simcable E-sky to turnigy 9x? | NiceOh | Radios | 0 | Nov 15, 2010 06:58 AM |
Help! | Finding a 72Mhz TX Module for Turnigy/FlySky/Eurgle 9x transmitter | penpen | Radios | 13 | Oct 29, 2010 01:38 AM |
