Nov 04, 2012, 12:47 PM
Promoting Model Aviation...
Murocflyer's Avatar
Build Log
Model Airplane Building Clinic #2 ~ Building From Plans >>Murocflyer<<
This thread will detail building an airplane called the E-Quickie 200 from a set of plans.
This build clinic is part 2 of a series of build clinics tailored for the beginner to expert builder of model airplanes. The original thread can be found here: https://www.rcgroups.com/forums/show....php?t=1733597
I ordered the plans from: http://www.theolddog.net/Q-200_plans_Pg_1.html They arrived in only 3 days. The plans have a "shopping list" of everything that you need to complete the build. Very nice touch. Now I just need to check to see what I don't have and buy the remaining items before 29 Nov.
The wing cores I am using can be ordered from here: http://www.mwcores.com/servlet/Detail?no=220
Attached below is a PDF of the build instructions, but by looking at the plans, I'm not sure they will be needed, but good to have if you get stuck.
Speaking of getting stuck, there is also a build video of the E-Quickie 200 by the designer of the airplane which can be found here: http://www.theolddog.net/Q200_Build_Video.html
If you have any questions, please ask, and I hope you enjoy the build along with me. This should be fun.
Frank
Nov 04, 2012, 07:01 PM
Murocflyer's Avatar
Shopping List
Here is the shopping list. I plan on building this plane with no rudder. Some say you really don't need a rudder so we'll see how this bird flies without one.
Balsa sheet
1/32 x 3 x 36 (4)
3/32 x 3 x 36 (2)
1/4 x 4 x 36 (1)
1/8 x 4 x 36 (1)
Other balsa
1/4 x 1 x 36 Trailing edge (1)
1/8 x 1/4 x 36 Stick (1)
1/4 x 1/4 x 36 Triangle strip (1)
1/8 x 12 x 12 Ply (1)
1/8 x 3 Hardwood dowel (2)
Hardware
1.5 foam wheels (2)
.093 (3/32) x 36 Music wire (1) for landing gear
.0625 (1/16) x 36 Music wire (1) for push rods
Nylon tubes (2) for above
10-32 nylon bolt 1.5 (1)
Dubro #107 1/2A control horns (2)
Dubro #231 1/2A aileron linkage
CA hinges (17)
3/32 Wheel collars (2)
Other
15 minute epoxy
Foam safe CA
Covering film
Build Log #12 Model Airplane Building Clinic >> Pat Trittle's Fleet Model 2 << Mr_McGlue Balsa Builders 53 Jun 03, 2018 02:41 PM
Cool Model Airplane Building Clinic ~ Building A Kit Murocflyer Parkflyers 484 Mar 14, 2013 02:37 PM
Mini-HowTo Model Airplane Building Clinic #2 ~ Building From Plans >> Begins TBD. All Welcome Murocflyer Balsa Builders 79 Dec 12, 2012 10:58 AM
Build Log #1 Model Airplane Building Clinic >> Mountain Models/Laser Arts Switchback<< Murocflyer Balsa Builders 21 Nov 26, 2012 08:41 PM
Build Log #6 Model Airplane Building Clinic >> Mountain Models Lucky ACE << glazzies Balsa Builders 61 Oct 30, 2012 09:20 PM
