Jan 01, 2013, 09:24 AM
P. Tritle's Avatar
future bush plane designs... a DHC-2 Beaver?
Already in the works
Jan 01, 2013, 09:25 AM
I eat glue
Gee Charlie, I've got a nice, barely used Mills .75 you'd probably like!
Jan 02, 2013, 04:33 PM
P_J_Glor's Avatar
WHOOPEEE !!!
Pete G
Jan 02, 2013, 06:43 PM
I eat glue
60" I hope.
Jan 02, 2013, 08:55 PM
P. Tritle's Avatar
60 it is
Jan 02, 2013, 08:59 PM
I eat glue
Okay you're forgiven for it not being a 60" Fleet Canuk, cuz that's a bushplane too you guys!
Jan 03, 2013, 09:02 PM
Hi Pat, When the wings are built, do I have to build a Washout Jig to insure proper dihedral and washout alignment or is this already setup in the build?
Jan 03, 2013, 09:17 PM
P. Tritle's Avatar
RC, You don't have to use a washout jig, but it does somewhat simplify setting up the struts. The main thing with washout is not the amount -- "a little bit" will be just right, but most importantly is that both sides are the same. For that you can do the parrellel stick routine to see that the inner and outter values are the same.
PAT
Jan 03, 2013, 09:56 PM
philipa_240sx's Avatar
When I built Pat's clipped wing T-craft and the Berkeley Beaver, I just eyeballed it and got pretty close.
Getting biplane wings straight with equal washout has always been tricky for me. On the last build I had some wildly differing washout amounts. I think it may have been an interplane strut issue... Who knows?
When the time comes on the Nieuport 28 build, I'm definitely building Pat's washout jig.
Jan 03, 2013, 10:31 PM
PAT
Care to explain this Pat? parrellel stick routine
Jan 04, 2013, 06:37 AM
It's a common technique used in woodworking. Two straight sticks (winding sticks) are placed parallel to each other at opposite ends of the wing. You then sight down the wing from the wing tip. The winding sticks give you a visual aid to identify twist or washout.
Jan 04, 2013, 07:23 AM
Cut it twice, still too short
dglo's Avatar
OK, a Beaver would be pretty cool, but a 60" Storch would be VERY cool. There's a group of us that have been waiting a long time for that one. I think you'd have a dozen orders before the build thread was finished.
Doug
Jan 04, 2013, 10:23 AM
E-Challenged's Avatar
I finally bought a Robart incidence meter, it can do a number of different alignment checks, not just wing incidences. Probably not great for really small models though.
Jan 05, 2013, 02:00 PM
I'm a little confused on the proper dihedral and washout alignment. Would someone please explain the process and how to do this? This is my first scale plane from Pat and I don't want to mess it up. I would appreciate it explained so I can understand, no fancy abbreviations etc.
Jan 05, 2013, 03:37 PM
P. Tritle's Avatar
RC, Washout is a span-wise twist in the wing that reduces the angle of attack at the tip as compaired to the root -- at the tip, the Trailing Edge is higher then the Leading Edge. The idea is to get the wingtips to stall last. The dihedral is built into the wing joinery so there's no need to set up anything there.
PAT
Sold Brand New HobbyZone Super Cub DSM RTF... Gimpdiggity Aircraft - Electric - Airplanes (FS/W) 7 Oct 02, 2012 09:52 PM
For Sale Brand New Super Cub LP 2.4ghz reciever/esc unit Foam boy Aircraft - General - Radio Equipment (FS/W) 0 Dec 03, 2011 10:15 PM
Discussion A beginner with a brand-new plane -- HobbyZone Super Cub cmerighe Electric Plane Talk 30 Nov 13, 2010 11:49 AM
For Sale Hobby Zone Super Cub RTF - Almost brand spankin' new hypnolobster Aircraft - Electric - Airplanes (FS/W) 1 Mar 22, 2009 03:46 PM
Brand New H9 Super Cub with Fuji 32B gas engine! flymyplane Aircraft - Fuel - Airplanes (FS/W) 0 Jan 24, 2005 04:55 PM
