Nov 03, 2012, 08:42 AM
P. Tritle's Avatar
Build Log
Brand New 60" Super Cub
Well, after months of head scratching and drafting the results are finally in. The original drawings were extremely "scale", and incorperated scale flap and aileron hinging, but because of the sheer complexity of the build would have been rediculously complicated for the average builder, so we rolled things back a bit and went with a more conventional layout so that everyone who wants to build a Super Cub can.
The model is done in 1:7 scale with 5 ch. control using 6 servos to accomodate the plug in wing arrangement which provides a much cleaner scale appearence without the bolt holes and break line across the top of the fuselage. Power is a Suppo 2217/9 with a 20A ESC and a 2S 1800 battery. So, let's get started.
Nov 03, 2012, 08:44 AM
P. Tritle's Avatar
Beginning with the Tail Section
Unlike the J-3, the rudder is rounded and the elevator is set up with boost tabs . Construction here is the typical bowed outline style.
Nov 03, 2012, 08:49 AM
P. Tritle's Avatar
Building the Wings
The wings are of the "Egg-Crate" style construction and incorperate front, rear, and full length hinge spar for the flaps and ailerons. The tips are bowed using 3 laminations that will be supplied with the Short Kit to simplify shaping since the taper will be set up going in, eliminating a whole bunch of carving.
Nov 03, 2012, 08:51 AM
P. Tritle's Avatar
Finishing the Wing Assembly
Once the basic wing assembly is completed it's lifted from the board, sanded to rough shape and the LE sheeting added. Then the final sanding and shaping is done to complete the assembly.
Nov 03, 2012, 08:54 AM
P. Tritle's Avatar
Framing the Fuselage
The fuselage is the typical "stick frame" style. The side door opens, so the fuselage sides are unique to their side. Framing plans will be included for both sides, just to keep things simple. The frasmes are joined directly over the plans beginning with the landing gear mount beams and upper cabin formers.
Nov 03, 2012, 09:00 AM
P. Tritle's Avatar
Continuing On Towards the Rear
The tail post is then aligned and glued and the aft formers, cross pieces and centerline stringer was added. From there it was on to adding all the stringers, front sheeting, cabin out-fill and the laminated "D"-Window frames. And finally, the landing gear mount gussets were added.
Nov 03, 2012, 09:03 AM
P. Tritle's Avatar
Adding the Details
The boot cowl and cabin side cover was cut from file folder paper, fitted, and glued in place with canopy glue.
Nov 03, 2012, 09:05 AM
P. Tritle's Avatar
Installing the Servos
The rudder and elevator servos were mounted aft to make room for cocpit details that can be added at any time.
Nov 03, 2012, 09:08 AM
P. Tritle's Avatar
More Details.....
The cowl plug was carved from blue foam and is out for vac-forming even as we speak. The windshield pattern was made up -- and will be provided on the plans -- and fitted to the frame. Then the landing gear assembly was built up directly on the fuselage frame to insure that it would fit properly when the time came to mount it permanently.
Nov 03, 2012, 09:18 AM
I eat glue
Sooooooooooooooooo- how does she fly?
What's next in the 60" size, oh say a Fleet Canuk 80, on floats. Prettyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy please.
Nov 03, 2012, 09:24 AM
P. Tritle's Avatar
Fitting the Struts
The struts were built up and fitted to the model using the Washout Jig to insure proper dihedral and washout alignment.
The motor mount was built uop and glued in place and the motor was mounted on the firewall. Holes are provided for either the Suppo 2217 or the E-Flite 450, so most motor applications in that size class should fit.
Nov 03, 2012, 09:31 AM
P. Tritle's Avatar
Cover and Trim
The model was covered with white Microlite and trimmed in black cut from stock vinyl sheet. The numbers are ordered, and once in place, the rest of the striping will ne added.
The wheels were cut from a big block of EPP foam that a friend scrounged up from somewhere. The hubs are from an old set of DuBro 2" wheels and were hot glued into the tire in a hole cut into the foam using a hole saw made from a .45 caliber ACP brass shell case. The rest of the tire was hand carved, then final shaping was done with a carbide sanding bar on the lathe
The cabin windows and windshield were glued in place and will be trimmed with white vinyl sheet.
Once the cowl and decals arive we'll get the Super Cub finished up and in the air, so stay tuned, it won't be long now.....
PAT
Nov 03, 2012, 09:36 AM
Looking good Pat!
I soooo wish I could have waited a bit longer for this one, as I'm now building your 53" Super Cub, which so far is going very well, but I wouldn't mind something bigger, with the plug in wings. But as it is, it would be hard explaining to the wife why I needed a second plane that's just like one I already have, so I'll have to keep this one in mind for the future. Also, I really have no room left for any planes, and I still have one kit to build after the SC is covered.
Now, a 60" Aeronca Sedan, on the other hand...
Nov 03, 2012, 09:53 AM
Visitor from Reality
Great treatment of another version of the classic Cub, Pat.
It's on the list when/if stability ever shows up hereabouts. Right now, all our 'stuff' is piled up in my shop in anticipation of a week of house painting. Can't even see the model I was building up to last week
But you probably don't to see my favourite Super Cub photo...
D
Nov 03, 2012, 03:25 PM
Bryan D
Zia Flyer's Avatar
WOW, Looks beautiful, Im building a Sig 1/20 Cub i bought from Jay. BTW amazing job on her.
Sold Brand New HobbyZone Super Cub DSM RTF... Gimpdiggity Aircraft - Electric - Airplanes (FS/W) 7 Oct 02, 2012 09:52 PM
For Sale Brand New Super Cub LP 2.4ghz reciever/esc unit Foam boy Aircraft - General - Radio Equipment (FS/W) 0 Dec 03, 2011 10:15 PM
Discussion A beginner with a brand-new plane -- HobbyZone Super Cub cmerighe Electric Plane Talk 30 Nov 13, 2010 11:49 AM
For Sale Hobby Zone Super Cub RTF - Almost brand spankin' new hypnolobster Aircraft - Electric - Airplanes (FS/W) 1 Mar 22, 2009 03:46 PM
Brand New H9 Super Cub with Fuji 32B gas engine! flymyplane Aircraft - Fuel - Airplanes (FS/W) 0 Jan 24, 2005 04:55 PM
