Oct 30, 2012, 02:59 PM
anyone have some idea what my numbers would be with this set up?
295kv 3 blade 12x8 prop on 12s?? thats what im going to try on my Nitroplanes foremost in a pusher application. USING 60c 4000mah gens ace pack and 120hv esc.
Oct 31, 2012, 01:59 PM
Zen in the art of foam
djacob7's Avatar
2, 3 and 5.
Oct 31, 2012, 09:30 PM
Ginger or MaryAnn ??
fh64_lucky's Avatar
I will say 1 , 4 and 6
Nov 04, 2012, 09:48 PM
Dr Kiwi's Avatar
I guessed at an E-flite 110 (295Kv):
Motor: E-Flite Power 110 Outrunner 295KV; 295rpm/V; 1.2A no-load; 0.03 Ohms.
Battery: Thunder Power TP6600 (G4 SportRace 25C) (25C); 12 cells; 6600mAh @ 3.7V; 0.003 Ohms/cell.
Speed Control: Scorpion Commander 110A; 0.0008 Ohms; High rate.
Drive System: Direct; 12x8 3-bladed (Pconst=1.62; Tconst=1) direct drive.
Airframe: Anything you want.
Conditions: 700ft above Sea Level, 29.92inHg, 68F
Motor Amps = 60.0
Motor Volts = 42.2
Input (W) = 2529.6
Prop RPM = 11592
Thrust (oz) = 294.9
PSpd (mph) = 87.8
Take out your Wattmeter and measure what you get.
Nov 04, 2012, 10:07 PM
will do some test in the next few days
having some issues with the retracts.
Question Would anyone have an idea of what this is worth? ghostmechanic Trader Talk 17 May 20, 2008 08:14 AM
Would this work? How'd it have to be set up? RastaManBob Motorcycles 8 Nov 23, 2004 11:00 AM
What would be best e set up for this Macthstick Parkflyers 1 Jun 03, 2004 02:33 AM
What would be the perfect set up for this plane? ttnissan Sport Planes 3 Nov 12, 2001 02:22 AM
