Oct 28, 2012, 06:52 PM
R2R
R2R
St Augustine RC Flyers
R2R's Avatar
Build Log
Hi-Flight Mirage Build
Last year I picked up an old Mirage kit NIB on RCGroups. I started it in December, glued the ribs and spar on the center panel, got the spar and ribs glued on one tip panel, and then put it away. I've pulled it back out and started the build again.
The top spar has .60" carbon. The bottom spar has .30" carbon. The spars are 3/8" wide in the center panel.
Allan
Oct 28, 2012, 06:59 PM
R2R
R2R
R2R's Avatar
I started by making laminated carbon spar caps for the center panel (see above).
I then glued the ribs and shear webs to the center panel. And I glued the top spar cap to the shearwebs/ribs using gorilla glue so that the few gaps would be filled as the GG expanded.
Oct 28, 2012, 07:04 PM
R2R
R2R
R2R's Avatar
I wrapped the spar and glued up the left tip panel.
This is where I left off last winter.
Oct 28, 2012, 07:15 PM
R2R
R2R
R2R's Avatar
Starting again today
Today I got back on the build. The stock trailing edge piece was warped, so I replaced half of it with wood from my LHS. I notched the TE pieces of the center panel and Titebonded them on.
Oct 28, 2012, 07:45 PM
life long racing nut & modeler
granada don's Avatar
Tip's
Since your main spar is so stong now, you might blow the tips off as they are kinda spindley at the joiner!!
G Don
Oct 28, 2012, 08:44 PM
R2R
R2R
R2R's Avatar
Thanks, G Don. I was pondering how and how much to beef up the joiner. I think the joiners have always been the weak link by design, but they probably do need to be strengthened now. Maybe just laminate the plywood joiner with glass/carbon? I'm not looking to do gorilla launches though; I just wanted to add a bit of insurance.
Oct 28, 2012, 09:16 PM
I have one of those NIB.
Oct 28, 2012, 09:39 PM
Hi R2R
I was thinking about where the joiner ends at those 1/8' spars, that looks like it needs a look see.
Maybe make the joiner out of 1/8" aircraft ply and put a long taper on it to spread out the load over 3" or so longer than the stock one.
You could make it out of 2 layers of ply glued together with some carbon cloth in the center, that is how i made my 12' Goose joiners yrs ago.
G Don
Oct 28, 2012, 10:18 PM
Gasbags & Gussets
jswain's Avatar
lite-ply joiners
I am planning on using two layers of 1/16" aircraft ply to create one joiner simply because the 3 layer 1/8" lite-ply is too weak imho.There was a discussion of this issue in earlier Mirage build threads. What i got from these threads it was you wanted the joiner itself to break vs. the joiner box. Also that the joiner to not fail due to a simple ground loop as was thought to be with the 1/8" lite-ply joiner. I'm also planning to upsize by the joiner box ply - i think its 1/64 as supplied but i'd like to use 1/32" - 1/64 obviously works but that was with 6v winche so my thinking goes
fyi- some useful references i plan to incorporate - http://www.mrcss.org/articles/6-cons...icle-isamirage Mirage info in two places, the middle and the very bottom part of this web page.
best wishes and thanks for posting the project, john s.
Oct 29, 2012, 01:46 AM
MrE
MrE
If you beef up the tip panels you will be killing one of the very best features of this plane - light tips. It wont turn or indicate lift nearly as well as the stock model.
IMHO the Mirage is one model that should not be beefed up in any way. It flys outstandingly well as is and will withstand moderate winch launches as is.
Ive broken one or both of my 1/8th liteply joiners several times now and Im very very glad they are what broke. I have had it cartwheel 50 feet across the field in 20 mph winds, a vertical nose first "arrival" and Ive fluttered the wing - all with NO damage to the wings other than broken joiners and some torn covering.
If the joiners had been stronger, Im quite certain I would have been building new tips more than once.
I have never broken a joiner in-flight except for the flutter issue - which happened on another vertical decent that got way over speed. Ive never broken a joiner landing. Only that cartwheel issue when I failed to weight it down enough when the wind came up during a contest. That cartwheel broke the rudder, elevator and fuse but the wing was fine.
I would highly recommend you resist all temptations to make it stronger. You're just making so that it cant fly at its full potential.
Oct 29, 2012, 01:56 AM
MrE
MrE
Now that Ive given you a hard time - sorry about that
Im curious - are you planning to add spoilers? Thats the one mod I do recommend. They make all the difference in the world as far as being able to land this thing on the spot and just getting it down out of big lift!
I started mine one bay in from the joiner rib and made them 1.5" wide starting from the back of the spar x a little over 10" long. I forget if that 3 or 4 bays wide.
The Mirage will float on mouse farts and glide in ground effect forever, so you really need some help getting it down and stopping it where you want it to stop.
Ok, enough preaching, I promise
Oct 29, 2012, 07:28 AM
Great build! I built one a few years ago from an Isthums Models kit, great kit if anyone is looking for a good kit to build. I did break the jointers twice on mine. First time I had built it per the plans which mentioned gluing the jointers into either the center or tips, bad idea, don't glue them in. So I remade them out of lite ply again and on the winch I broke one but had enough tape holding the tip one that I still flew it for a 2:30 minute flight. After that I used ply that was I think about 6 thin layers and it has worked great.
Alan
Oct 29, 2012, 09:27 AM
Gasbags & Gussets
jswain's Avatar
good preaching is always welcome
...The Mirage will float on mouse farts and glide in ground effect forever, so you really need some help getting it down and stopping it where you want it to stop.
Preaching about experiences is OK
This is great info and I really appreciate it from those who have 'walked the walk' when they share it. Ultimately this kind of info makes the end product work better for the builders and flying.
js
Oct 29, 2012, 10:39 AM
Be the duck. Whaaaa?
UberZogster's Avatar
Totally OT but is that a vase of Artichokes?
Oct 29, 2012, 12:58 PM
craigrrr's Avatar
As for spoilers, I would recommend making them four bays wide.
I agree that spoilers are a must; I built mine three bays long. Three bays is plenty
for landing, but I think four bays would be a good thing for extraction from boomers. I have flown for 30 minutes, spoilers deployed, without loosing altitude (on a good day).
As for joiners, mine are made out of seven ply wood. They have never broken. They are not glued in (but they should be a fairly tight fit -build up edges with epoxy if too slopy). But once when flying way too fast I tore a wing tip panel off. I was able to bring it back to my mini field for a semi-controled landing without the wing tip panel. The failure was in the wing tip panel, just beyond the joiner box. But I retreived the wing tip panel and it was an easy fix.
I attach the wing tip panels with a two inch long piece of 3/4" wide fiberglass reenforced packing tape on both leading and trailing edges.
I do recommend wrapping joiner boxes with kevlar thread (along with a light wrapping on the entire center spar).
I totally agree with MrE about adding NOTHING to the tip panels (except a little kevlar thread around joiner boxes). Light weight tips are a big part of making it possible for the Mirage to stand vertically on a wing tip and be very maneuverable.
Keeping this bird light is very important if you want it to fly like a Mirage. I have been flying sailplanes for 42 years and the Mirage is my favorite woody RES. I also own a Graupner Cirrus, Oly IIs, Windfree - great planes, but usually stay in the hangar. The Mirage is addictive.
Craig
Discussion Scale Piper Malibu Mirage Scratch design and build. rbneville Scale Kit/Scratch Built 2 Mar 06, 2013 12:37 PM
New Product MIRAGE IIID Aussie Scheme! & BUILD LOG Extreme_RC Australia 26 Jan 26, 2013 04:42 PM
Build Log Megajets Mirage 2000 Build Guide superscott Foamies (Kits) 12 Jun 01, 2012 05:38 PM
Discussion Exceed RC Mirage 2000 EDF64 - Video Review, Build & Flight nitroplanes Vendor Talk 1 Feb 03, 2009 06:51 PM
