Apr 04, 2013, 08:46 AM
Good luck Ben !
Apr 13, 2013, 04:07 AM
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
Today I achieved prop making zen - I made a prop and was completely relaxed and thoroughly enjoyed it. Must be getting used to it eh?
Also here is a 6.25x11 made with 150g carbon. I thought it would be too thick but it worked very well indeed. I got it from a very high profile sailboat mast maker via QDR (think Americas Cup boats) and have a suspicion it may even be high modulus.
I don't think you'd break this prop!
Apr 13, 2013, 05:08 AM
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Very very nice!
Apr 14, 2013, 06:52 AM
SB7
SB7
I am actually really slow
It's surprising just how heavy you can go Dean. I used 160g for a lot of my stuff. Even some 240gTwill for the F3D stuff.
Apr 14, 2013, 05:23 PM
miche's Avatar
Static test DUP folding prop 6x10
Static test @ 950m ASL:
- Neu motor 1115 2Y (1400kv)
- CC ICE ESC 100
- Folding prop DUP 6x10 = 5.8" diam. w/BB Aluminum Turbo Spinner 30mm
- Lipo: 5S TP1800mah (3S+2S)
- Power peak: 1137W
- Current peak: 62.6amp
- rpm peak: 23044rpm
Apr 15, 2013, 08:06 AM
"The Judge"
sebbe's Avatar
miche , thanks, I wunder how much amps will be on same type/size motor only 1900kv...
Could it be ICE 100 shows a little to high amps ?
My calculations says 120-130 amps, 29000rpm with 5s and 1900kv motor..
now what was the rpm tested with these 6x10, hmmm ?? what is mopar who did test ?
Apr 15, 2013, 08:46 AM
Why the dirt on the wings?
moparmyway's Avatar
Sebbe, sorry but I dont know what you are asking .......
Apr 15, 2013, 09:40 AM
"The Judge"
sebbe's Avatar
,, my bad english, I meant: was it mopar(you) who did the test with the 6x10...
Cant find that video..
Apr 15, 2013, 12:02 PM
Are we there yet?
feefo's Avatar
It was DUP's 4.7 x 6.1 (6.2?) that Mopar did a vid with, you can find it on the 'Build your own folders' thread, middle of this page https://www.rcgroups.com/forums/show...660562&page=50
Apr 15, 2013, 01:23 PM
"The Judge"
sebbe's Avatar
yepp, remember now,,,,, ok,
DUP, maybee you can answer, is there problems with the 6x10 and 30K rpm ?
Apr 15, 2013, 03:38 PM
How do you mean Sebbe?
Also, a small correction, Miche has the 6.25x11, his is a special size of 6.1x11. Also note with a smaller hub, we reduce the pitch so he's got a 5.7 or 5.8 x ???
Apr 15, 2013, 03:41 PM
Mty (Tamas) has calculated the following for the 4.7*6.1 folder:
From moparmyway's and feefo's data we can use two data points for the 4.7 prop:
46613 RPM, 2621 W
25479 RPM, 425 W
RPM ^ 3 / Pinput = const
46613 ^ 3 / 2621 = 3.864e+10
25479 ^ 3 / 425 = 3.892e+10
The two constants are within 1% from each other, so the data are pretty consistent and the below equation can be used to estimate the required power input (with a MEGA motor) for any RPM (subsonic).
Pin = RPM ^ 3 / 3.864e+10
Apr 15, 2013, 04:05 PM
"The Judge"
sebbe's Avatar
Hello, Is the 6x10 safe for 30K ?
Apr 15, 2013, 04:29 PM
Oh, for sure, I built the 7x10, 6.25x11 and 6x10 for myself really, no issue with them running at 30K.
I think Arctic flyer ran the 7x10's to 5.5KW, not sure of the RPM though:
https://www.rcgroups.com/forums/show...&postcount=464
Apr 16, 2013, 02:50 AM
"The Judge"
sebbe's Avatar
sounds nice, thanks,,, I think 5.5kw must be much more then 30K... I feel secure now
Discussion 4S 8" props vs 3S 10" props Performance & Flight Times GuerillaFilm Multirotor Drone Talk 12 Sep 16, 2012 06:50 PM
Discussion Prop Balancer for High Performance TheBlood+ High Performance 27 Apr 04, 2012 03:58 PM
Sold NIB Aquacraft GrimRacer High Performance Prop L42x66 sgil2001 Boats (FS/W) 2 Jul 26, 2010 11:12 PM
Sold 2 Graupner CAM high performance props new in original packages -- $7 shipped for both SPasierb Aircraft - Electric - Power Systems (FS/W) 2 Jan 14, 2009 06:09 PM
For Sale High Performance Prodigy wing kits ,with or w/o motor/prop sylair Aircraft - Electric - Airplanes (FS/W) 2 Aug 20, 2008 01:44 PM
