Yikes...Is that the top speed? That is well below what I was hoping for and expecting. I really hope it's not such a dog with the stock setup.
1) EDF fans do not use centrifugal force to move air - here's a centrifugal compressor, doesn't quite match what's in an EDF
![]() 2) This is for electric motors: unlike fuel motors, which are constant power, electric motors are constant rpm, i.e., the motor will work to maintain rpm for a given voltage, drawing more current as the loading is increased until it reaches stall torque. As the number of blades increase, the point of maximum efficiency drops as the torque/rpm increases (i.e. at a lower current level), resulting in more heat loss compared to power delivered as current draw increases at higher rpms. ![]() Here is an interesting article about ducts: http://4wings.com.phtemp.com/tip/tpdduct.html Addendum: In some cases the fan blades can hit stall speed, so the stall torque is never reached. |
Reason: clarifying
You can fly with 4000 but i dont recommend it. Flying time will be at 2min or 2min30sec i think. CG won't be a problem, you will have to add about 30 or 40 grams of lead in the nose. Best regards Roman Ready2fly.com |
that is what I would know! Whether I extra weights need in the nose. 40 grams are no problem. ![]() Thanks again. Kind regards Erich |
![]() ![]() ![]() Quote:
![]() Quote:
Latest blog entry: Freewing Me262
Eric B. OK now you explain how you come up with your answer? |
Reason: spelling
It's not the blade count that matters, it's the combined chrod of all blades! A 2 bladed fan would be very long/thick while the high blade count fans are short with less chord per blade for the same power input.
How many blades you choose is more a matter of what's practical for your application in terms of fan dimensions. Just grab this, as this is they way it works! |
I'm not arguing that pitch isn't the reason, I'm just stating that they all have a factor work together. Like I said you can't have one without the other. If you want an equation 1 + 1 = 2 , they go hand in hand. ![]() |
Again not arguing yours and airX points, they are true. However the above 2 Wemo pics show what I'm trying to say and you said it yourself " they have about the same pitch". They don't have the same pitch, "about the same" isn't the same, although it slightly differnce in pitch there is one. So I'll say it one last time pitch and blade count go hand in hand.
Henk,
Thanks for the pics! |
