Here is a short video of our control throws.
Beautiful Sunny & Calm day today to get me some Yakkity action..
Freewing Yak 130 90mm 6S Maiden at TiredIron Aviation
Heavy and flys like a pig but it looks pretty good to me. Plus I have pavement to fly off of so I don't see were its going to be an issue! Let me know your thoughts. |
Yeah I'm not getting the same results, seems plenty fast on 6S and that takeoff on grass was with no flaps and it sounds great so I don't know if the motor has been changed on these later ones or not. This one has a 12 blade 1700 KV inrunner.
The manual says 1600 KV, but it actually has a 1700 and the web page says 1700 so maybe the earlier ones had the 1600.
Hi guys
Can someone/anyone kindly give their opinion of the stock oleos/retracts please? I love the look of them, considering a full set for an edf project that will weigh in at 3-3.5kg TOW Doing a quick search I read of some retract issues but didn't seem to be prolific problems? Are the oleos robust enough for general ops? I read some guys flying 8s @ 4.5kg TOW Thanks ever so |
Agreed but the Trailing links work well on Grass absorbing bumps & potholes for normal ops as long as they don't get stressed on that joint .. Don't hit any iron grates on landing..
And duly noted. I am surprised they have relied on unsupported plastic portions of the oleos for such a gorgeous scale beauty, and a little weighty at that. Well, their gear isn't overly expensive so it may well be a punt. The only other gear worth looking at that I've seen is the F-15c but I'd have to rotate the mains 90 degrees, but looks like it is all metal, also trailing link, but the nose wheel looks small. Ahhhh, the joys of experimentation... |
I've decided I'll get the all metal trailing link mains from the T-45 and the metal trailing link nose from this Yak 130. Best of both worlds, all metal and all trailing link. Many thanks |
The Mains off the T-45 sit very high as opposed to the Yak's .. It sits much higher than the F-15's
