ORX T-Six (OrangeRX Transmitter) - Page 113 - RC Groups
Nov 06, 2017, 01:08 PM
removed battery for 1 day and then reinstalled. Same problem. Does anyone know if there is a button or jumper switch on the motherboard to reset the system?
tjcooper
Nov 10, 2017, 06:46 PM
SOLUTION: I saw earlier in this thread where people had similar "throttle warning" error. They thought it was battery. So I charged my LiPo to full and tried again. Got same warning, but noticed that if I held the throttle stick down hard, that the "setting" value started to drop from 34%. Eventually with a lot of playing around, I got it to go to 0% and the throttle warning turned off. Now I can control my models and get to all the menus.
SOLUTION: patience at holding down the throttle for a long time.
new problem of the trim switch for rudder only working in one direction. Took apart case and all screws on controller board for switches. THen the rudder trim worked again. So that is solved. Now the throttle level will not change from full. I think I have bumped some of the controller wires and need to re-solder.
So if I get it all working again, will I trust it to fly an airplane or a drone in the air? What if it locks up when I am flying? I see that Banggood.com has the same unit for $75 called FrSky. Is it worth replacing or should I move up to something else that will give me better operational features and reliability? Looking for comments.
tjcooper
Nov 11, 2017, 10:04 AM
No bounce, No play.
davidmc36's Avatar
Move up to better system. Fr Sky has nice budget Tx now.
Spektrum has a couple lower priced units.
Graupner has really new 12 channel Tx.
Many good choices better than Orange.
Nov 11, 2017, 11:25 PM
UPDATE: did re-solder of leads. That was not solution, the pc on the bot is flaky. If you push on it and glue it down, then it works for awhile, then stop again. So unit is toast and I move on. I have the EVO from Multiplex so I know a good unit when I see one, but things are changing too quickly these days. Want a 9 channel for air and drone. FrSky has 7 channel for good price. Looking at others.
tjcooper
Nov 11, 2017, 11:37 PM
60 years of RC flying
Daedalus66's Avatar
Seven channel FrSky??? The QX7 is 16 or more.
Nov 12, 2017, 05:49 PM
Aim:
To allow for RC loss condition, bind Orx T6 transmitter to receiver while in "throttle cut" mode to set that as the receivers fail-safe. I'm using Arducopter on a multirotor so this would initiate Return To Launch if there's RC loss.
Problem:
Orx T6 wont output any signal at all or bind while there's any warning or error, cant bind with throttle cut switch operated. Also I don't want to bind with flight mode switch in RTL mode as I'll probably end up altering flight modes and switch positions and forget about fail-safe; In that case RC loss would initiate some other flight mode and actions or crash.
Solution:
Set throttle travel to 125% down, this takes the PWM output into the throttle fail-safe region, about 975PWM on my T6. This is similar to having the throttle cut switch operated. I also set the Arducopter throttle fail-safe level to 990PWM just to be sure.
Now bind to receiver with the throttle on minimum and switches in normal positions.
Set throttle travel back to default 100% down.
Test by turning the transmitter off and observe flight controller behaviour via groundstation - QGC, APM Planner or Mission Planner - you should get a throttle fail-safe and initiate Return To Launch.
Nov 25, 2017, 02:58 AM
fix you won't believe for ORX-T6
UPDATE: the failure of my ORX-T6 has finally been fixed.....and you won't believe it. The failure of the Tx pot was not changed in the long term by re-soldering the Tx pot leads. The system would start and fail randomly. Eventually I realized that if I put LATERAL pressure on the Tx pot it would work well.
So I drilled an 1/8" whole in the left side of the orange case. I put in a cotton Q-tip to push laterally on the pot. That made the Tx work in all conditions. So my permanent solution is to put a bead of RTV in the case to put the same pressure on the pot. I have tested at the field and it performs as good as new. No worry of failure in the air because the throttle cut switch can be used to power down the throttle any time I needed. With a very light SLICK twisted foamy it can crash with no throttle and cause no damage to the airplane or a person on the flight line.
Go see this new ORX-T6 substitute by Banggood called the JUMPER:
RF Chip Data
Cyprus Semiconductor CYRF6936: DSM/DSMX, Walkera Devo
Texas Instruments CC2500: FrSky, Futaba SFHSS
Amiccom A7105: FlySky, FlySky AFHDS2A, Hubsan
Nordic Semiconductor NRF24L01: HiSky, Syma, ASSAN and most other Chinese models
Macnufacturer RF Chip Example Protocols
Cyprus Semiconductor CYRF6936 DSM/DSMX
Walkera Devo
J6Pro
Texas Instruments CC2500 FrSky
Futaba SFHSS
Amiccom A7105 Flysky
Flysky AFHDS2A
Hubsan
Nordic Semiconductor NRF24L01 HiSky
Syma
ASSAN
it looks like it can fly all the modules I have ever used. Will arrive in a few days and I will test it out.
tjcooper
Sold Tactic six channel 2.4ghz transmitter and receiver TurboRacer Aircraft - General - Radio Equipment (FS/W) 2 Sep 18, 2012 03:04 PM
Question T-Rex 450 SE v2 Turnigy Batteries and OrangeRx receivers? Edude625 Beginner Training Area (Heli-Electric) 5 Nov 27, 2011 08:05 PM
Discussion HK SS Series 18-20A ESC + OrangeRx Futaba FASST - No beeps, motor doesn't move :( lpinho Power Systems 5 Aug 16, 2011 06:29 PM
Discussion DSM2 6ch OrangeRX won't bind--won't even flash the LED horseflesh Radios 12 Jun 09, 2011 12:06 AM
Will my six volt rc system hurt my transmitter? randall1959 Aerial Photography 2 Jul 10, 2005 12:41 AM
