Durafly AUTO-G Gyrocopter - Page 166 - RC Groups
Mar 08, 2017, 12:49 PM
Blade holder modifications
This is how I did with mine, which allows lead/lag and "may" save the holder in case of blade strike.
And the blades can be folded for transportation too.
Mar 08, 2017, 06:13 PM
britinoz's Avatar
Good idea...that should work OK...
Mar 14, 2017, 04:57 PM
roidspop's Avatar
I've been flying the G2 for a couple of years now and have had my shares of crashes and other unexpected arrivals. That's part of the game!
More often than not these have occurred during takeoff...low rotor speed and premature liftoff. When it was working properly, the prerotator generally got the gyro into the air in good shape, but we've all seen what happens to the original flex drive...it turns into a tangle of raveled wire that's pretty much useless.
I've been working on an alternative to the Durafly drive and this is what I've come up with. This current version has been through about forty flights so far and is performing very well (knock on wood!) . I'll skip all the details and just give the gist of the thing. There are three sections to the shaft; the long part is a small hardwood dowel. The two stub shafts installed in the drive section and rotor head have taken several different forms, but the main thing is that the section that goes into the fitting needs to be a snug fit, have a flat for the set screw to engage with, and should be made of steel, nothing else. The sections are joined together by flex couplings made of silicone fuel tubing. As simple as that is it has worked astoundingly well.
I'm not going to attempt to tell you exactly how to make one of these but will be happy to supply more info if anyone requests it. I will say that there's no way of telling how long the drive will last, but so far, it has lasted longer than the original and it is EASY to repair or replace.
Mar 14, 2017, 06:07 PM
PSALM 14:1
Sammy70's Avatar
Nice job on the new drive shaft setup
Latest blog entry: Umx r2
Mar 14, 2017, 10:33 PM
Loctite 603 for the pre-rotator drive flex shaft
Good idea!
I've been using the LOCTITE 603 - Retaining Compound for all of my flex drive fast speed boats with great result. At first I didn't believe that this Loctite 603 will hold the flex drive cable into the drive shaft better that the old silver solder method.
I did the same to my Auto G2 pre-rotator drive shaft, so far so good.
How to use LOCTITE 603 - Retaining Compound (1 min 56 sec)
Note: you have to let it cure overnight though. In case of my Auto G2, no disassemble required.
Mar 15, 2017, 12:49 PM
roidspop's Avatar
This looks like a really good thing to do to a new flex cable before it's had a chance to be wrecked the way they usually are. Do you have to remove the cable from the couplings before treating it? Do you just put the loctite on the ends and if so, how long a section do you treat?
Mar 15, 2017, 06:44 PM
See "note" under the picture, which says,............no disassemble required.
I put the Loctite 603 directly to the flex cable just next to the coupler making sure not too much or it will overflow.
1. With the Auto G2 right side up, gently put as less as possible to the "base" of the flex shaft where it goes into the coupler, then wait a few minutes and see if found it way inside then you may add a little more. You should let it sit several hours.
2. Turn the G2 upside down, and do the same for the other end. You can use a tooth pick here because it is somewhat way inside the wooden frame, just applt the Loctite to the end of the tooth pick then apply accordingly.
3. let it sit overnight to fully cure.
You may also want to check if the grub screws are fully tighten onto the flex shaft, if not once you loosen the screws you should put a little blue Loctite 242 before putting them back on.
Mar 15, 2017, 10:22 PM
roidspop's Avatar
Makes perfect sense. Anybody who's buying a new G2 (or a Super G) should do this before they ever fly it. If they've already wrecked their flex shaft, then maybe they should try building one along the lines I suggested up there.
Jun 28, 2017, 02:59 PM
Cantaloupeman's Avatar
Originally Posted by JetPlaneFlyer
Yes, but how much depends on what you use as a datum. Relative to the flat bottom of the blade the wedge installed under the blade gives about 3.5 to 4 degrees negative. Relative to the chord line of the blade airfoil (which is what incidence is usually measured from) it's about 1.5 - 2 deg negative.
So the auto g2 blades do have negative pitch?
Jun 29, 2017, 01:46 PM
Have a look at question 19) here: https://www.rcgroups.com/forums/show...ns-and-Answers
Jul 30, 2017, 03:14 PM
Sensation! Boomerang rotor...
have a laugh at my expense - make sure you watch the end of the video
EDIT: First thought that the reason for the crash was a loss of signal, but Ralf W (see post 2488 below) analyzed correctly that the rotor flew off in mid-air, not as a result of the crash
Auto-G Durafly maiden crash w/ boomerang surprise (1 min 14 sec)
Last edited by mopetista; Aug 04, 2017 at 05:02 PM. Reason: thanks to Ralf for the correct analysis!
Jul 30, 2017, 03:16 PM
PSALM 14:1
Sammy70's Avatar
Amazing!
Jul 30, 2017, 04:35 PM
Originally Posted by mopetista
the crash is most likely due to loss of signal, [/url]
No - it crashed due to loss of rotor! Have a look at your extraordinary video in slow motion (0,25%). At 1:03 you see the rotor parting and then the gyro crashes down while the rotor bumerangs home.
Jul 30, 2017, 04:58 PM
thanks for checking! I had a plane come down at around that spot the same day, so it seemed obvious that it must have been a radio issue - must check the thread for suggestions how to fix the rotor
Jul 30, 2017, 10:18 PM
the crash is most likely due to loss of signal, I do have problems with reception in this area, and I had not taken care how the mini antennas of the RX were oriented, just stuffed everything in
damage: prop, and with some luck nothing else, have only checked the motor shaft (it runs true), before my next trial I will browse this thread for the things you have to know, I just naively tossed it in the air
https://youtu.be/1qoMXgdgFmI
This vid killed me lol 😂😂
Help! Slow-g slow stick auto gyro HyperHelis Auto Gyros 4 May 23, 2012 09:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 06, 2006 12:27 AM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 08:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 03:35 PM
