Sanwa SD-10G: Deal or Disaster? - RC Groups
Oct 26, 2012, 09:39 AM
U2Milo's Avatar
Question
I have a lead on a Sanwa-branded SD-10G. As you may know, Airtronics distributes these in the US with their own label.
A call to Airtronics USA confirmed they will support the Sanwa model. The electrical plugs are US spec. The programming language and manual is English. Seller says it will talk to US-spec receivers.
Have any of you SVSSers heard of any other reason to stay away from this? I would otherwise buy from a local hobby shop, but this is such a good deal.
Mitch Valder
Rocklin CA
Oct 26, 2012, 01:41 PM
Team Hello Kitty
SoaringDude's Avatar
If you can get return privileges on this purchase then I would go ahead and try it.
The 10G has worked very well for me with the caveat that you need to be very careful when you buy transmitters used from a 3rd party. I had a bad experience with one. The new one has worked flawlessly for 2 years.
Chris B.
Nov 05, 2012, 04:51 PM
jtlsf5's Avatar
This response may be a bit late, but here's my advice. Chris is right, buying used has it's risks. I would suggest this. Offer this to the seller. You will purchase and send to Airtronics to be thoroughly checked out and tuned, which you will pay for. If there is any other repairs that are required the seller would pick those up. If he agrees, go for it. If not, pass on it. This way you get a freshly checked/tuned TX, and any needed repairs get covered by the seller. If seller is confident in the quality of his TX it should be a no brainer.
JT
For Sale Used twice Sanwa (Airtronics) SD-10G TX chrismog Aircraft - General - Radio Equipment (FS/W) 6 Jan 02, 2013 05:23 PM
Discussion Hacking a Sanwa (ATX) SD-10G - Frsky gizzo Radios 7 Jul 28, 2012 07:15 PM
Alert Sanwa SD-10G FHSS3 RX-1011FS 10CH 2.4G Radio System $310 !! old_dude Hot Online Deals 1 Feb 15, 2012 11:25 PM
Discussion Airtronics/sanwa SD-10g 3810 Australia 5 Feb 24, 2011 03:44 AM
Discussion Sanwa (Airtronics) SD-10G programming F3B Motormike Radios 2 Jul 29, 2010 01:03 AM
