I've found the easiest way to install the gws prop is to remove the prop adapter, remove stock prop, then install gws prop. The nut needs to flipped around, it's fits into the gws hub. Then tighten the prop and install prop adapter to motor shaft. There's just enough clearance between spinner and cowl to stick an allen wench in there to tighten the set screws. Then you'll need to trim the nose cone for prop clearance.
I have the neon orange gws 7x3.5. They were $.99 @ lhs. It's not the slow fly version. The gws seemed to be the most well balanced out of the bunch, much more than stock and apc props. I even balanced the apc but didn't balance the gws!
The problem with gws props is the hub is longer than stock, won't fit adapter unless you shave hub or install nut backwards. If you install it with nut backwards you need to spin the prop to tighten, only problem is motor spins too. I found it much easier to take the adapter off to tighten the prop first.
I guess the props I tried are gws ep 7035 SF, here's a link, https://www.hobbyking.com/hobbyking/s...6pcs_set_.html
cool so mine are good. they're gws dd 7035 ep. (direct drive 7x3.5 electric power) not slowfly. so in your opinion the best replacement for now. thanks for ya help i got 7 460 nanotechs, 6 props and no plane hopefully not to long now |
I kno that feels bro Going down to the lhs today, and hopefully coming back with mine
ain't even available here in UK yet. preordered mine. I popped by my lhs last night as they had a demo model in. it looks perfect, I tried to buy it for 1 and half times the rrp. lol they wasnt having none of it. perfect addition to the fleet right between my umx's and 3DHS slick42.
Very nice review! Gives me some hope for this plane. FedEx says Tuesday for mine. Will have the day off. Many test batts on the way. Stuck in Utah at this time for Thanksgiving. Heading out the door to my favorite LHS to check out the E540QQ. rc |
Is your favorite LHS by any chance West Valley Hobbies?
Thread Tools | |
Similar Threads | |||||
New Product | E-flite 300 A6M5 Zero BNF Basic | Afraidtoregister | Electric Warbirds | 1299 | Sep 29, 2022 09:46 PM |
Sold | BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS | peterswolf | Aircraft - Electric - Micro & Indoor Airplanes (FS/W) | 4 | Sep 14, 2012 07:43 PM |
For Sale | E-Flite MSR X BNF Basic edition | daign | Aircraft - Electric - Helis (FS/W) | 0 | Jun 01, 2012 08:59 PM |
Sold | Edge 540 3D ARF by E-Flite | freirem | Aircraft - Electric - Airplanes (FS/W) | 2 | Feb 28, 2012 07:38 PM |
Discussion | A6M5 Zero 300 BNF Basic by E-flite | BlazingStar | Micro Ready-to-Fly | 2 | Feb 03, 2012 03:22 AM |
