Oct 21, 2012, 05:18 PM
There's Something in the Air
Ne-Aero's Avatar
Electric Motor equivalent setup for a 150cc composite IMAC airplane
Hi all,
I have a Krill Models 39% Katana composite airplane sitting in a box waiting for me to get to it. It looks like this winter I'll have the chance to put this beast together. I had originally planned on moving my DA-150 over to this airplane when my 40% Extra 330 crashed or broke, but that has not happened yet (10 years). But by now I'd rather go electric. So I'd like to get a sampling of what planes and setups people are using to fly 150cc-sized Aerobatic airplanes. A good synopsis format would be:
- Airplane (make, wingspan in inches, model)
- Motor
- Prop
- ESC
- Battery cells and capacity (i.e., 12S 5000mAh)
- AUW (lbs.)
- WOT Current (amps)
- WOT Power (watts)
- Flight times (min.)
Tanks in advance,
John
Oct 23, 2012, 03:30 PM
My set-up:
- Airplane: Zlin 526 AFS (Own design, WS 3200mm/126")
- Motor: Plettenberg Predator 37/6
- Prop: Engel 30x16
- ESC: Hacker Master Spin 220
- Battery cells and capacity: 12S 18000mAh(3x8Ah in parallel)
- AUW: 19.7kg / 43.4 lbs
- WOT Current: 275 amps
- WOT Power: 12000W
- Flight times: 10 min.+
Regareds,
Magne
Oct 23, 2012, 11:36 PM
Turnigy/hobbyking has a 150cc rotormax motor. Looks nice but don't have any experience with it. Big ESCs you are looking at the Jeti Spin and MGM Pro and maybe YGE. Hobbyking, fightercat and XPS dont seem to have the HV escs anymore.
Nov 02, 2012, 07:12 PM
BE77 Pilot's Avatar
Originally Posted by Magne
My set-up:
- Prop: Engel 30x16
- WOT Power: 12000W
Regareds,
Magne
All I can say is WOW! That must be a killer plane.
Nov 03, 2012, 09:12 AM
WATTSUP.SE
Jocke's Avatar
http://wattsup-power.blogspot.se/201...xperience.html
Look at my blog and you find some experience and setup data with the Predator 37.
12s CC 160HV is OK, with a strong set of LiPo you will get 11kw power, Mejzliks EVO-L and in combination with F (foam core) you get the lightest and strongest prop available today. 30x13" or 31x12". The 30x13" EVO LF is 220g !!!!.
But if you want a real power punch on a 40% you need to go 14s for power above 12kw, you will have to use props that may rip the blade tips at high rpm and high speed, but you will have 15-16kw of efficient power by using 28x12" to, 29x12", untill there are EVO versions ready in this size the 29x12" S is a good choice. For 14s setups the Jeti SPIN 300 is the way to go (same as Hacker/ Jeti 220) the current will be up to and above 300A.
Discussion The official thread for electric powered setups for 50cc sized 3D airplanes racin06 Giant Electric Planes 371 Mar 04, 2019 01:09 PM
Discussion best 3d/IMAC electric airplane in the 30"-50" class tesla000 Electric Plane Talk 1 Oct 12, 2010 01:57 AM
For Sale CSRC Perfect setup for MS Composit Hellcat 450 Size E5-L-8 Motor and 12Amp 2-3s ESC jmrust Aircraft - Electric - Power Systems (FS/W) 1 Jun 24, 2010 03:36 PM
Found Trade electric setup for airplane for quality Heli Gyro grumpy trol Aircraft - General - Radio Equipment (FS/W) 2 Aug 29, 2009 05:10 PM
Aveox Equiv for Hacker B50 F5J Setup SoarNeck High Performance 2 Jul 02, 2003 01:56 PM
