Oct 21, 2012, 02:47 PM
robertus's Avatar
Build Log
X-Shuttle, my wing for night (and not only) flying - plans
I want to build a flying wing for the evening flight.
At this point, I'm after maiden flight. The prototype is built of foam insulation.
The target model will be made ​​of white 6mm depron because I want to insert into the LED lights.
A few photos of construction.
I started from the wing of the space shuttle and i put thick profile.
And some pictures from building.
Building is very simple. The plane has only a few parts. Stiffness is results from the shape of the fuselage.
CoG i 17cm from the engine mount.
That glides empty plane. Without any additional weight!
X-Shuttle - Glide tests (0 min 40 sec)
Engine mount
And this is The Maiden
X-Shuttle Maiden Flight (6 min 5 sec)
My equipment:
engine emax cf2812
prop APC 7x4
accu 3S850mAh
weight to fly 350gram
Plans in post #13
Oct 21, 2012, 03:12 PM
skumgummi dave
Robertus:
That is amazing. It glides like a feather and tracks like an arrow. Beautiful in its simplicity of design. You have another winner sir...
Dave-
Oct 21, 2012, 03:30 PM
robertus's Avatar
Now, the wing loading is only 12grams/dm2, its about 4oz/ft2
I can add a lot of lights without excessive loss of flight parameters.
Oct 21, 2012, 04:18 PM
X-shuttle
Hi Robertus, beautiful, design, and model. What a great flier, great video.May I ask if the wing loading figure is of the model without gear (motor, battery etc) or ready to fly. Cheers
Oct 21, 2012, 06:43 PM
i can't learn fast enough
Really nice job.
Is that the new green foam?.
Friend of mine gave me a couple of sheets, but it seemed kinda heavy.
Will you be making plans available?
I like the way you blended the topside to the wing.
Keep us informed, and again nice job.
Terry
Oct 21, 2012, 09:34 PM
Krued Up
snolord1's Avatar
got the pdfs
would love to build this with lights
Oct 22, 2012, 12:05 AM
Zen in the art of foam
djacob7's Avatar
Very neat design and great flying!
Where is the equipment access (opening)?
Oct 22, 2012, 01:02 AM
robertus's Avatar
Ready to fly. And there is no gear.
Battery bay is under fuselage.
Originally Posted by Terry Glenn
Really nice job.
Terry
Maybe Foam is generally available in Poland.
Empty plane, just foam, weighs 120grams
More flights
X-Shuttle Some flights (5 min 20 sec)
Oct 22, 2012, 03:25 AM
Quad Erat Demonstrandum
scousethief's Avatar
They had loads of that green foam available over here in the UK around 18 months ago i didnt pick any up because i prefer depron but it looked good enough.
Very nice build Robertus
Oct 22, 2012, 11:01 AM
robertus's Avatar
I want to fly at dusk. Sometimes in the dark.
I would like to use the neon wires. Such as these.
But I wonder if they will visible at dusk (at sunset) enough.
Oct 24, 2012, 08:21 AM
Garage Foamologist...
mrjoshua's Avatar
Awesome design robertus, that X shuttle tracks perfectly. I need another go fast project, will you be posting drawings?
BTW, my buddy flies a Stryker with lights similar to those in the picture, they give off plenty of light for flying at dusk.
Oct 24, 2012, 08:48 AM
Love the design
Very nice design ,good job will you be posting the plans ???...I hope so .. would love to build one thanks ....
Oct 24, 2012, 10:33 AM
robertus's Avatar
Glad to hear it. I've just ordered neons.
I disassembled the prototype and I took the picture cross section. Note how I trimed foam.
The battery bay is not tested yet.
Plans
50mm = 2inches
Oct 24, 2012, 03:59 PM
skumgummi dave
robertus:
Thank you very much for the plan for the x-shuttle. I look forward to building it. I still like your hammi the best... )
Warm regards;
Dave-
Oct 25, 2012, 02:54 PM
Nice plane robertus. I am looking forward to building it. Thanks for sharing.
Discussion My night flying set up bill clark Night Flying 2 Aug 25, 2012 04:12 PM
Discussion My night flying Dji NAZA Quad The_RattleSnake Night Flying 0 Jun 12, 2012 11:02 AM
Micro Max Wing, my first indoor flying(..X,) wing Sparr Scratchbuilt Indoor and Micro Models 5 Aug 28, 2002 02:25 PM
