Oct 20, 2012, 09:16 AM
Help!
Calibrating ESC with Devo 7 tx/rx.
Many FC configuration's suggest that ESC's need to be calibrated yet using an ardupilot 2.5 mega FC I can't do it via software like I can on openpilot cc.
Problem is my Devo 7 tx requires me to put the throttle control at zero position before it starts to work when I first connect to the rx on the quad.
So, I turn on tx, then the rx on multi wait about 5seconds when the link and then rx/tx are linked.
There is no way to start the multi sequence with the throttle all the way up so the ESC'think they are getting programmed.
I do not find a means to turn this "safety feature" off on the Devo tx.
Any suggestions
Rolf
Oct 20, 2012, 05:28 PM
Connecticut Quad Hacker
batfire's Avatar
Any suggestions
Rolf
hi Rolf
Hope this explains what you are asking for. This works for all Tx/Rx combos. I also own Devo 7 and 10 works for them.
eRC Speed Controller Trouble Shooting: How To (6 min 30 sec)
Oct 20, 2012, 08:18 PM
<Marty>
i think what is happening is the tx and rx needs a few seconds to bind and this time closes the window needed to calibrate the esc...if i remember correct once the devo is binded to the rx you can unplug the battery to the rx and it remembers the ID ...so try this...turn on the tx , plug in the battery to the rx and let them bind...then unplug the battery and place the throttle to high position then plug the battery back in and the tx/rx should rebind quickly and allow you to do the calibration...
Oct 22, 2012, 07:15 AM
Thanks Guys.... I gave these this a couple of trys yesterday and still don't know if they are properly configured but the quad does seem to fly relatively ok...
unstable for the first perhaps 10 seconds of flight then balances out (ardupilot 2.5)
Perhaps just need to tweek the PIDS some more.
Rolf
Mini-HowTo Update Firmware for Devo TX - Import/Export Devo TX Models - Update Devo RX Firmware Tom Z Micro Helis 22 Jun 28, 2015 12:20 AM
Wanted Found sbillingham Aircraft - General - Radio Equipment (FS/W) 3 Oct 20, 2012 12:19 PM
Wanted Found sbillingham Aircraft - General - Miscellaneous (FS/W) 1 Oct 20, 2012 09:12 AM
Found Found sbillingham Aircraft - General - Radio Equipment (FS/W) 0 Oct 18, 2012 06:47 PM
Wanted Found sbillingham Aircraft - General - Radio Equipment (FS/W) 0 Oct 17, 2012 12:57 PM
