Oct 19, 2013, 10:48 AM
redwhskers
redwhskers's Avatar
You can make field repairs and fly in 15 mins. Heat if a little with a heat gun and you can move or remove to replaces a part try that with CA.
Build Fly Fix
RW
Jan 20, 2016, 10:09 PM
Wind wind go away
geekdom's Avatar
Digging this up, does Foam-Tac work with Elapor? Al la Multiplex foam?
Much appreciated!
Jan 10, 2019, 12:30 AM
Much appreciated!
I have used Foam-Tac to glue the wing of my Parkmaster Pro and also glued an XT-60 connector in the wing so I can just plug the battery in the wing. Even the 3 motor connectors are glued to the fuselage and they stick like........ glue
Discussion Beacon Foam Tac Adhesive in Stock The Don Product Announcements 5 Jul 06, 2012 01:15 AM
Discussion Is my Beacon Foam-Tac ruined/ too old to use StewieRC Foamies (Scratchbuilt) 1 May 22, 2012 12:43 PM
Question Beacon Foam Tac Glue vs. 2 Part Epoxy stekeye Foamy EDFs 11 Feb 22, 2012 07:52 PM
Discussion Beacon Foam-Tac EPP hinges squishy654 Foamies (Scratchbuilt) 14 Apr 06, 2011 06:11 AM
