FMS BF-109 1400mm 14x8x3 prop and spinner. G32 700KV motor 3s 4000mah 55C GPlus
Did you notice any difference in your power draw or flight envelope?
On another topic, for those who run differential on your ailerons, who much do you set? Mine rolls terribly, so I want to try differential to see how it helps. |
from LET: Heliflyer14, Power on 3s is not as punchy as it would be on 4s but ill let the video speak for itself. It flies very stable, and landings are seemingly more stable with this bigger prop configuration if you look at all the videos the landings are all pretty much greased.... just keeping the throttle on until the mains touch and rog to slow on final. |
Got some good flights with mine yesterday!!
Latest blog entry: Eflite 80mm F-4 with my Afterburner...
Wow, fancy flying there gooniac
![]() One question for you, if I recall correctly, you have differential setup on your ailerons, correct? What are your settings for those? Right now, my rolls are really terrible, and I have to time full down elev when going through the inverted portion, else it becomes a giant barrel role. |
Cool video
![]() I wish my Gee Bee would roll nice and tight like yours. Are you just a superior pilot, or did you make any adjustments to help out the roll, like differential? Out of curiosity, what camera did you have mounted on the bottom side of your Gee Bee? |
Thanks |
Great little camcorder. |
I haven't flown mine in a while. But I did yesterday! Its so much fun to fly! I didn't have to touch any of the trim even after sitting for months. I have glued the tail in place and replaced hinges with blenderm. I think that if I added a gyro this thing would be even better! Maybe I will... anyway here are my flights!
Been a while since I've posted a flight video of the ol' Gee Bee Y
Thread Tools | |
Similar Threads | |||||
Mini-Review | Nitroplanes.com Dynam 4 Channel Dynam SU-26M 47'' Brushless Sportsplane | Nitro_Nancy | Sport Planes | 3 | Dec 10, 2016 03:13 PM |
Question | Dynam transmitter used on all dynam planes? or just the one it came with? | Dominick Zola | Electric Plane Talk | 5 | Apr 12, 2012 10:05 AM |
Wanted | Super Sportster & Sportster Bipe Plans. | Stephen Bennett | Aircraft - Fuel - Airplanes (FS/W) | 2 | May 18, 2008 03:22 AM |
need stuff for mini geebe lilpols charger prop rx and | new flyer | Aircraft - Electric - Airplanes (FS/W) | 7 | Sep 16, 2004 02:51 PM |
