Oct 12, 2012, 06:14 AM
billisfree's Avatar
Grease for Nylon gears
My Super Cub Cessna has ruined two sets of gearboxes now, overheated the bearings and prop shaft flew off. Somebody sold me this plane without the instruction manual.
What is best lubercant to use on nylon to plastic surfaces?
Vaseline? Light machine oil? Lithium grease?
Oct 12, 2012, 09:10 AM
Redacted per NSA "suggestion"
dedStik's Avatar
Be aware that petroleum based lubes may actually damage the nylon, try this http://secure.hobbyzone.com/search/t...FQqZ4AodfFMAkg
Oct 12, 2012, 09:28 AM
LesUyeda's Avatar
You should NOT have to lubricate nylon gears. I would check the clearance between gears, and ensure that they are not too tightly meshed.
Les
Oct 12, 2012, 10:05 AM
tacx's Avatar
Les
AHAA, Don't servos have grease on their nylon gears?
Oct 12, 2012, 10:33 AM
lcm1977's Avatar
I use white lithium grease on my servo gears. Never had to lube a gearbox. I would go with Les on that one. Make sure your gears are meshing correctly, not too tight or loose, and everything is lined up straight and no bent shafts. If your prop is way out of balance, that could stress the system too.
Oct 12, 2012, 12:10 PM
Night Flying
Ron H's Avatar
Originally Posted by billisfree View Post
overheated bearings
Light machine oil
Lube the bearings, not the gears.
Oct 12, 2012, 12:16 PM
St. Louis
Foambird's Avatar
Lube
Petroleum based lubricants are not friendly to plastic or nylon parts. Nylon gears don't need lube.
Oct 12, 2012, 12:52 PM
AMA 994002
matiac's Avatar
I was gonna say Lithium Grease too. It's what I use on my Fishing Reels that have nylon gears, which ain't NONE of my Saltwater stuff...
Oct 12, 2012, 01:54 PM
flydiver's Avatar
The grease can attract dirt, which will contribute to rapid wear. All by itself grease will not harm the nylon gears. If they are exposed during ground maneuvers the overall effect will probably be more damage than help.
I've used a spray on DRY Teflon lube I found in a hardware store. Seemed to help a tad.
Oct 12, 2012, 04:56 PM
Nylon is a tough & slick material. If you get the teeth too tight. they can distort for a while & cause some noise
Oct 12, 2012, 06:42 PM
Or current resident
glewis's Avatar
I use dry graphite powder sold as a lock lubricant. Once you get a nice even coat of it in the gears it is there for good and doesn't need to be replaced or replenished. It's dry, so it won't attract dirt and it also won't harm the plastic. It really quiets the gear noise too.
Glenn
Oct 12, 2012, 08:18 PM
flypaper 2's Avatar
Lithium white grease is synthetic so won't hurt the gears.
Gord.
Oct 12, 2012, 08:52 PM
Not failing=Not trying enough
Wehrdo's Avatar
Silicone lubricant also won't hurt plastic.
Oct 12, 2012, 09:50 PM
billisfree's Avatar
Thanks all.
My "melted" area is the pressure plate between the gear and the plastic.
It gets hot... nylon gear hub gets soft... plane seems to have weak power for a bit, then shaft pulls free of the gear... prop goes bye-bye. Hub and plastic show signs of meltdown.
OK, I won't try to lub the gears now.
Sold 2- Hitec HS 80/101 nylon gear sets NIP raceredg Aircraft - General - Radio Equipment (FS/W) 0 Jun 24, 2012 04:56 PM
tail servo for corona-metal or nylon gear? RabelRouse Electric Heli Talk 3 Jul 16, 2004 07:15 PM
HS81 nylon gears swap with metal gears TwinSpar Hitec/Multiplex USA 7 Mar 12, 2004 09:37 PM
fuji 86cc twin and nylon gear bolts for 33% EXTRA330L Cody WIlson Giant Scale Airplanes 0 Mar 04, 2004 12:23 PM
grease for nylon gears dale331 Electric Plane Talk 5 Sep 21, 2001 05:35 PM
