Old Oct 12, 2012, 06:27 AM
mookiee is offline
Find More Posts by mookiee
Mini-HowTo
Slow Flaps on 10 CG
I was trying to figure out how to get slow flaps on my 10CG. Here's how i did it.
To get slow flaps working, change your model from ACRO to GLIDER, There are plenty of pre set mixes, you may have to add some of your own. I'm using GLID(2A+2F)
I've never flown a glider, but most of you will already know that there are 4 flight settings: i have "start", gear down, few degrees of flap, "Speed" Gear up no flap, "Landing" Gear down 3/4 Flap i havent used the 4th one.
To get the throttle working change the airbrake from VRe to Stick, i'm using this on my HK viperjet. To set the delay for the flaps go into offsets and apply the delay to the flaps.
Its a shame they didnt just put a delay function in ACRO for flaps.
Old Oct 12, 2012, 11:16 AM
Hasse H is offline
Find More Posts by Hasse H
Hasse H's Avatar
Aurora 9 has delay on every channel, in acro, glider and heli.
Old Oct 12, 2012, 11:21 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
There are many other radios that have servo speed reducer.
DX7s,DX8,DX10t & DX18 all have this feature.
Not sure why some manufacturer chose to put this feature in some model type only.
Help! CG point of home made Slow Stick Blade Crasher Foamies (Scratchbuilt) 2 Aug 30, 2012 10:46 PM
Question Flaps on a CG eagle 2 ithia Beginner Training Area (Fuel) 23 May 22, 2012 02:01 PM
Help! help regarding deploy flaps with Futaba 10 CG Johnsmith122 Radios 14 Apr 13, 2012 11:08 AM
Placement of CG on Slow Stick tumbleweed Beginner Training Area (Aircraft-Electric) 13 Feb 06, 2003 08:45 AM
