Well i've done it for 3 charges and it did the same on all..i've charged it with the original charger and a Accucel6 that i got for my rc truck..the blades spin freely tho not as loose as i've seen on some vids..the blades are well spaced from the bottom like 5mm or so
Well the battery lasted 7-10 minutes every charge till now..that is 3 charges..last time i've hold the quad in the air as long as i could after the leds started blinking till it went down on it's own..the power loss when it's in mid air is slight but enogh for it to go down
Sounds like you may have a motor going bad, I had a similar problem with mine where it would fly for a bit then just loose power even at 100% throttle and drop to the floor. All the props were spinning but no power to lift off, the motor finally died completely and I replaced it. Flys fine again...
Just curious how long did it fly after the lights started bliking.
Thread Tools | |
Similar Threads | |||||
Discussion | The Hubsan X4 | youxif | Multirotor Drone Talk | 102 | Feb 20, 2017 06:43 PM |
Discussion | Hubsan x4 6axis | scousethief | Mini Multirotor Drones | 301 | May 13, 2015 09:31 AM |
Discussion | Hubsan X4 Mini Quad | dc9guy | Mini Multirotor Drones | 32 | Feb 04, 2013 11:14 PM |
Hitec X4-80 eighty 4 port chager review search | Timewarp | Batteries and Chargers | 4 | Jun 22, 2012 04:20 PM |
