Nov 30, 2003, 03:56 PM
Measuring control surface throw
What are you fellows using to measure degree of throw on the control surfaces?
Michael
Nov 30, 2003, 05:39 PM
Burnin' holes in the sky!
SkyPyro's Avatar
A calibrated eyeball I just get as much throw as I can, or estimate 45* for test flights. On the ailerons, I make a bluecor template of the aileron with less throw, then limit the other one to that much throw so I don't have any differential.
Dan
Nov 30, 2003, 05:44 PM
40%, 5% whats the diff?
TeamSME's Avatar
Use a protractor. Line it up and check throws.
Sean
Dec 01, 2003, 08:30 AM
eflyguy
Andy W's Avatar
What Dan said. Think of it as clock hands. If the wing (big hand) is on the 9 and the aileron (little hand) moves between 1 and 5, you've got about enough for 3d!
For more subtle measurements (i.e. 1/8" evelator for an F5B model) I use a ruler.
..a
