Sep 23, 2012, 01:41 PM
Aileron & Rudder Transmitter Mix For Landing Or Otherwise - Good Or Bad?
EDITED: I'm curious about whether or not some RC pilots sometimes (or always) might use an aileron/rudder mix programmed into their transmitter for landings or otherwise? If for other than landings when do you use it?
Thanks for your thoughts?
Sep 23, 2012, 01:46 PM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
I've never heard of an aileron to elevator mix. I cant even hazard a guess as to why you would want to slave elevator off of aileron input (or vice versa) for landing or for anything else
Do you maybe mean a flap to elevator mix, where the flaps are 'flaperons'?
Sep 23, 2012, 03:20 PM
I meant rudder DUH!
Sep 23, 2012, 03:45 PM
A lot of high tech sailplane guys slave rudder and ailerons to get easy to fly circling patters in a thermal. Then they can focus on trying to read the updraft.
Probably most pilots use mixes to make their planes act a little more "regular".
But I always wanted to learn to fly the raw plane, and mix controls on the sticks. If it needs rudder to turn, I want to learn to manually put in rudder. The only reason that I use exponential is in a plane that is VERY sensitive (to calm it down), or a plane where one axis is much more sensitive than the others (to make the throws of the sticks to mean the same thing in all channels).
I think that I am in the minority.
Sep 23, 2012, 06:13 PM
What about using a Mix switch to add a certain amount of up elevator in the final leg of the landing approach?
Discussion Mixing Aileron And Elevator (V-Type Mix) -How To Waleed Radios 22 Feb 12, 2017 05:58 PM
Question Mixing aileron rudder elevator parambir Giant Scale Airplanes 3 Aug 20, 2012 03:01 PM
Discussion elevator to flap mix using aileron servos?? big bird Hitec/Multiplex USA 2 Mar 21, 2012 05:15 AM
Discussion Elevator and Aileron gyros for Taileron without Mixing othmanskn Electric Plane Talk 11 Dec 05, 2010 06:16 AM
Mixing for Alliance (rudder, elevator,ailerons) JensJakob68 Electric Plane Talk 4 Dec 07, 2001 10:07 AM
