Oct 14, 2021, 02:30 PM
Dantiel's Avatar
beautiful doctor, the first servo flapping ornithopter with articulated wings.
probably the spring needs to be weaker to bend by little weight and allow a higher amplitude of flapping.
Oct 14, 2021, 05:24 PM
K Kakuta
Kazu-kaku's Avatar
Thank you.
Oct 14, 2021, 09:38 PM
K Kakuta
Kazu-kaku's Avatar
Making of ServoFlapOrnithopter MountainHawkEagle99 with Articulated wings   15
SFOMountainHawkEagel99 with Articulated wings: Flapping Test of Articulated Wing
サーボ駆動クマタカ型羽ばたき機 SFOMountainHawkEagel99 with Articulated wings: Flapping Test of Articulated Wing (2 min 52 sec)
Oct 15, 2021, 11:01 PM
K Kakuta
Kazu-kaku's Avatar
SFORhamphorhynchus93-3 7th Flight Test : Flight & Gliding under cloud
サーボ駆動翼竜型羽ばたき機 雲の下で飛行 SFORhamphorhynchus93-3 7th Flight Test : Flight & Gliding under cloud (4 min 14 sec)
Oct 16, 2021, 08:45 PM
K Kakuta
Kazu-kaku's Avatar
SFOPterodactyl95-2 12th Test Flight under cloud
サーボ駆動短尾翼竜型羽ばたき機 SFOPterodactyl95-2 12th Test Flight under cloud (6 min 38 sec)
Oct 17, 2021, 07:22 PM
K Kakuta
Kazu-kaku's Avatar
Making of ServoFlapOrnithopter MountainHawkEagle99 with Articulated wings   16
Making of Surface Body
Oct 17, 2021, 07:24 PM
K Kakuta
Kazu-kaku's Avatar
Making of ServoFlapOrnithopter MountainHawkEagle99 with Articulated wings   17
Now State Weight 33g Wingspan 85cm Length 40cm
Oct 17, 2021, 08:28 PM
K Kakuta
Kazu-kaku's Avatar
SFORhamphorhynchus93-2 13th Flight Test : Slope Soaring on small step in North Wind
サーボ駆動翼竜型羽ばたき機スロープソアリングSFORhamphorhynchus93-2 13th Flight : Slope Soaring on small step in North Wind (8 min 22 sec)
Oct 18, 2021, 06:44 AM
K Kakuta
Kazu-kaku's Avatar
Making of ServoFlapOrnithopter MountainHawkEagle99 with Articulated wings   18
Painting 33g
Oct 18, 2021, 10:21 AM
Dantiel's Avatar
great work doctor. the slope soaring is really good for servo ornithopter, but maybe there can be stronger slopes, for example on buildings or walls
Oct 19, 2021, 07:52 PM
K Kakuta
Kazu-kaku's Avatar
Making of ServoFlapOrnithopter MountainHawkEagle99 with Articulated wings   19
ServoFlapOrnithopterMountainHawkEagel99 with Articulated wings: 2nd Flight Test at Seaside : Good Flight and Gliding
サーボ駆動クマタカ型羽ばたき機 翼に関節がある SFOMountainHawkEagel99: 2nd Flight Test at Seaside : Good Flight and Gliding (4 min 57 sec)
Oct 20, 2021, 08:05 PM
K Kakuta
Kazu-kaku's Avatar
Try to make large ServoFlapOrnithopter Pteranodon97-- wingspan 2960mm 21
SFOPteranodon97 with short wings Wingspan 296cm with New Servo : Flight Test 8
サーボ駆動翼竜型羽ばたき機 試験飛行8 短い翼 新Servo SFOP97 with short wingsWingspan 296cm with New Servo Flight Test 8 (8 min 30 sec)
Oct 21, 2021, 02:03 AM
Dantiel's Avatar
amazing the new servos seem very promising, but the ptero may have overweight a bit.
a reason for servo to drop power is usually that theres not enough current from battery, but it may also be by overheat
takemura uses this servo for flapping:
Servo drive type Ornithopter test 4 -- Good flight (3 min 46 sec)
curiously he run them on 3cell lipo, but he writes that a servo has died by overheat.
maybe you may try raise current to ~9V
EDIT: another reason for servos stopping may also be a "rotor locked" protection that some more high-class servos have, if this is happening shortening or narrowing the wings or try a stronger spring may help
Oct 21, 2021, 03:54 AM
K Kakuta
Kazu-kaku's Avatar
takemura uses this servo for flapping: https://www.youtube.com/watch?v=_WR-8EJUYNI
Thank you. I turned a wing into slim gradually and shortened gradually. I will try to do up Volt to 9V from 3cell Lipo.
Oct 21, 2021, 05:29 AM
K Kakuta
Kazu-kaku's Avatar
Lipo3cell -DC stepdown converter 9V5A or 9.5V5A
Discussion My stock DJI motors run pretty hot, here's a way to measure the temperature in flight jasper7821 Multirotor Drone Electronics 5 Aug 02, 2012 03:05 PM
Discussion My son's fourteen minute flight! Thomas Cummings Thermal 11 Jun 27, 2012 06:59 PM
Sold Brand new flight tested ZII, 2 flights on it fly's great ROCKY2 FPV Equipment (FS/W) 11 Jun 05, 2012 12:08 PM
Discussion My first flight with my new F550/WKM, Aeroxcraft landing gear and Contour GPS camera jasper7821 Multirotor Drone Talk 0 May 27, 2012 01:27 PM
