May 19, 2019, 05:47 AM
K Kakuta
Kazu-kaku's Avatar
Originally Posted by G-LO
Is this a "fuller size" falcon than the others? Looks larger. And this time it didn't seem you posted any build.
Falcon52iVST-3 is Female--Large. Falcon30iVV3--Male. Smaller.
Making of Falcon52iVST-3 is almost same as Falcon52iV.
May 19, 2019, 06:45 AM
K Kakuta
Kazu-kaku's Avatar
Falcon 30iVV3-1 : Longer Flight at Oosato in strong Wind by Double180mAh3cell
Falcon 30iVV3-1 : Longer Flight at Oosato in strong Wind by Double180mAh3cell (5 min 10 sec)
May 19, 2019, 08:23 AM
Hello, Dr. Kakuta.
If I remember it right you're using plastic gears from printers for gear box. What about long steel pinion? Where do you get it?
Also as I can see you are making wing membrane mostly out of Orcon films. Can you recommend any alternatives? It's hard to obtain one in my country.
Thank you very much. Your works are wonderful!
May 19, 2019, 05:46 PM
K Kakuta
Kazu-kaku's Avatar
Originally Posted by xfield
Hello, Dr. Kakuta.
66T Module0.4 Gear and 3mm shaft
https://www.aircraft-japan.com/ja/p1...gw-350c-box-ds
64pitch 8T pinion Wire
https://shop.sdp-si.com/catalog?cid=...ned&view=table
Orcon film---> Lamaguard10 or Icarex
May 19, 2019, 06:54 PM
K Kakuta
Kazu-kaku's Avatar
Falcon52iVPH-1 : Flight in Strong Wind
Falcon52iVPH-1 : Flight in Strong Wind (4 min 20 sec)
May 19, 2019, 09:50 PM
Wildlife Artist / RC Designer
DaVinciBrainchld's Avatar
Hello, Dr. Kakuta.
Hi xfield - you might want to check out the "Vijay new bird" thread. He uses a lot of alternative materials.
May 20, 2019, 09:43 AM
K Kakuta
Kazu-kaku's Avatar
LightFury23iV 3DP: Good Flight in Strong Wind
LightFury23iV 3DP: Good Flight in Strong Wind (3 min 38 sec)
May 20, 2019, 05:29 PM
K Kakuta
Kazu-kaku's Avatar
NightFury 23iV : Flight in Strong Wind
NightFury 23iV : Flight in Strong Wind (3 min 27 sec)
May 22, 2019, 06:37 PM
K Kakuta
Kazu-kaku's Avatar
Butterfly20-5-2 Flat Wing and V tail: Flight in Strong Wind at Oosato
Butterfly20-5-2 Flat Wing and V tail: Flight in Strong Wind at Oosato (2 min 37 sec)
May 23, 2019, 06:58 PM
K Kakuta
Kazu-kaku's Avatar
NightFury 23iV : Flight at Seaside by Boy
NightFury 23iV : Flight at Seaside by Boy (6 min 31 sec)
May 27, 2019, 10:08 AM
K Kakuta
Kazu-kaku's Avatar
Demo Flight of Ornithopter
Demo Flight of Ornithopter at Toride (19 min 41 sec)
Jun 02, 2019, 03:46 AM
K Kakuta
Kazu-kaku's Avatar
Manta62: Very Good Elegant Flight at Oosato
Manta62: Very Good Elegant Flight at Oosato (5 min 46 sec)
Jun 02, 2019, 07:05 PM
K Kakuta
Kazu-kaku's Avatar
Falcon 30iVV3-1 : Flight with Black Kite at Oosato
Falcon 30iVV3-1 : Flight with Black Kite at Oosato (5 min 7 sec)
Jun 03, 2019, 06:51 AM
K Kakuta
Kazu-kaku's Avatar
Banshee 7-12 : Flight at Oosato
Banshee 7-12 : Flight at Oosato (2 min 40 sec)
Jun 04, 2019, 07:39 AM
K Kakuta
Kazu-kaku's Avatar
FalcoHobby 22iV Two Motor for FPV : Flight at Oosato
FalcoHobby 22iV Two Motor for FPV : Flight at Oosato (3 min 29 sec)
Discussion My stock DJI motors run pretty hot, here's a way to measure the temperature in flight jasper7821 Multirotor Drone Electronics 5 Aug 02, 2012 03:05 PM
Discussion My son's fourteen minute flight! Thomas Cummings Thermal 11 Jun 27, 2012 06:59 PM
Sold Brand new flight tested ZII, 2 flights on it fly's great ROCKY2 FPV Equipment (FS/W) 11 Jun 05, 2012 12:08 PM
Discussion My first flight with my new F550/WKM, Aeroxcraft landing gear and Contour GPS camera jasper7821 Multirotor Drone Talk 0 May 27, 2012 01:27 PM
