The official MrRCSound system thread. - Page 209 - RC Groups
May 27, 2013, 08:33 PM
Originally Posted by Bob Dunlop
What Andrew was suggesting was to plug 1 amp into the balance on one 5s and the other amp on the 2nd balance...that way it should pull an even load from each 5s pack,so I think we're ok there...my only concern is if the balance leads on the lipos are capable of handling the load of the sound system
Thanks, Bob
It should be, yes. They system only draws about 1.7A at 12v from each. So I don't see why the leads would not handle that.
Andrew
May 27, 2013, 08:53 PM
Fokker,I didn't even kiss her
Bob Dunlop's Avatar
Andrew
Cool,thanks Andrew...just need to do some measuring and figure out where to hide all the speakers
May 27, 2013, 09:22 PM
Bob Dunlop's Avatar
Andrew, how's your WW1 sound chip coming along?
May 27, 2013, 10:31 PM
CarToon's Avatar
Originally Posted by 52Sabre
I've got the 1875mm Liberty Belle w/fmsvprops. Can you show some pics and explain your install? Thanks.
Here you go. Your installation may vary. You will notice the little bits of black foam tape at the corners of the speakers. I had drilled extra holes, since they are deep in the wing. Then I read (fortunately before I flew the plane) that you should not make extra holes, as it disturbs the cooling effect. So I taped 'em up, and slanted the walls of the hole to allow airflow.
I am using a 3s 1000 battery, installed in the nose for the sound unit power, which helps with the CG (3 oz.). Also had to add about 4 oz. of lead in the nose. The extra weight actually seems to stabilize the plane in flight, and there is no noticeable loss of speed, as if you need a lot of speed for a four engine bomber anyway. The sound is great, and it got a lot of attention and interest.
Because the holes might compromise the strength of the wing, I imbedded three strips of carbon fiber, as seen by the channels inner wing area.
May 27, 2013, 11:28 PM
Avionics tech
52Sabre's Avatar
CarToon - Doesn't multi-engine sound require multi sound boards? Where is your rcvr mounted? With extra weight up front, any problems with nose overs?
Be sure to see my new video posting (minus sound unit) over in the Liberty and Memphis Belle threads. Looking forward to your video as well.
May 28, 2013, 02:54 AM
CarToon's Avatar
It's a single sound board with the multi engine chip, but it needs two speakers. If you look at the first photo, the receiver is in the upper middle part of the photo.
Normally, with the correct CG (it does take some fiddling with), I don't have a nose over problem. But then, I fly off of a 600 foot asphalt runway. Also, I use two 2200 3s batteries.
May 28, 2013, 06:44 AM
The new forum is up!!! I will be creating a few threads, feel free to stop over, we will start posting there. This thread should soon be moved over to the new forum!!!
Andrew
May 28, 2013, 06:46 AM
Avionics tech
52Sabre's Avatar
CarToon - Ahh . . . I see it now. Black and hidden in the wires. Got so used to seeing an orange one. But, very nice my friend. I may just do that. Thanks for posting the pics. Didn't know there was a special chip.
May 28, 2013, 06:48 AM
Avionics tech
52Sabre's Avatar
Andrew
Give us a link.
May 28, 2013, 06:56 AM
Just a little ways down in the vendors forums.
https://www.rcgroups.com/mrrcsound-845/
May 28, 2013, 09:10 AM
Thank you all for your input in this thread. It has become very large with lots of information in it. Now with a MrRCsound forum we should be able to keep things a little more organized. I am closing this thread, but it will remain here for reference. Thank you for your support everyone!
Andrew
http://www.mrrcsound.com
New Product JR XG11 Owner's Thread ElIntocable Radios 693 Sep 11, 2017 05:44 PM
Discussion Official Eflite UMX Mig 15 DF Owners Thread NitroCharged Micro EDF Jets and Power Systems 5755 Aug 25, 2017 11:21 AM
Discussion Version 2.5 MrRCSound sound system. MrRCFlying Electric Plane Talk 1 Jan 07, 2014 05:41 AM
Discussion The Official Teen Chit Chat Thread (Always Off Topic) Alex Schauer Chit Chat 31697 Aug 27, 2013 07:56 PM
Sold Mrrcsound electric sound system with gun card. This is the pro version aquaanox Aircraft - Electric - Power Systems (FS/W) 3 Jul 05, 2012 10:11 AM
