Sep 03, 2012, 06:46 PM
Spektrum DX8 and DX18 SD log file format
Hi
I have try to debug/hack the format of the Spektrum DX8 and DX18 SD log file SPEKTRUM.TLM and this is what I found:
Format of the SPEKTRUM.TLM file:
Data block start with:
1 Time stamp Low byte
2 Time stamp
3 Time stamp
4 Time stamp high byte
5 Data type 00,16,17,7E,7F
6 ?
If Time stamp = FFFFFFFF then it is a header
Length of is 36 Byte
If 5 and 6 is equal then it is header Data
If 6 is 00 then it is name info
Then it repreat a 20 byte block:
2 Time stamp
3 Time stamp
Data type = 00
Dat type = 16
1 serial number
2 serial number
3 serial number
4 always 00
5 16 (Data type)
6 always 00
7 not identified is low byte of next (decimal)
8 not identified is high byte of previous (decimal)
9 1/100th of a degree second latitude (decimal)
10 degree seconds latitude (decimal)
11 degree minutes latitude (decimal)
12 degrees latitude (decimal)
13 1/100th of a degree second longitude (decimal)
14 degree seconds longitude (decimal)
15 degree minutes longitude (decimal)
16 degrees longitude (decimal)
17 1/10th of degree heading (decimal)
18 degrees heading first two numbers (decimal)
19 always 08
20 always 3B
so to get decimal degrees calculate:
latitude = {12} + {11}/60 + ( {10} + {9}/100)/3600
longitude = {16}+ {15}/60 + ({14} + {13}/100)/3600
heading ={18}*10 +{17}/10
Offset to google maps seems to be
lat= lat-0,003655 lon= lon-0,004572
Data type = 17
6 ?
7 Speed High
8 Speed Low
9 ? May be max speed High
10 ? May be max speed Low
11 ?
12 ?
13 ?
14 ?
15 ?
16 ?
17 ?
18 ?
19 ?
20 ?
Data type = 18
6 ?
7 Altitude High
8 Altitude Low the format is in intiger and is in 0.1m
9 ?
10 ?
11 ?
12 ?
13 ?
14 ?
15 ?
16 ?
17 ?
18 ?
19 ?
20 ?
Data type = 20
6 ?
7 x High
8 x Low
9 y High
10 y Low
11 z High
12 z Low
13 x max High
14 x max Low
15 y max High
16 y max Low
17 z max High
18 z max Low
19 z min High
20 z min Low
Data type = 126
6 ?
7 RPM High
8 RPM Low RPM = (RPM low + (RPM High * 256)) * count of Poles
9 Volt High
10 Volt Low V = (Volt low + (Volt High * 256)) / 100
11 Temp High
12 Temp Low F = Temp low + (Temp high * 256) C = ((Temp low + (Temp high * 256)) - 32) / 1,8
13 ?
14 ?
15 ?
16 ?
17 ?
18 ?
19 ?
20 ?
Data type = 127
6 ?
7 A High
8 A Low
9 B High
10 B Low
11 L High
12 L Low
13 R High
14 R Low
15 Frame loss High
16 Frame loss Low
17 Holds High
18 Holds Low
19 Tranciver Volt High
20 Tranciver Volt Low V = (Tranciver Volt Low + (Tranciver Volt High * 256)) / 100
Br.
Kim
Sep 04, 2012, 05:53 AM
Update:
Data type = 18
6 ?
7 Altitude High
9 ?
10 ?
11 ?
12 ?
13 ?
14 ?
15 ?
16 ?
17 ?
18 ?
19 ?
20 ?
Sep 04, 2012, 05:55 AM
I have made this VBA code to import logdata to Excel.
You need to update RPM_poles!
Code:
Sub Import_Spektrum_log()
    Dim intFileNum%
    Dim bytTemp As Byte
    Dim intCellRow As Long
    Dim dlgSaveAs As FileDialog
    Dim SourceDir As String
    Dim DataMode As Integer
    Dim DataByte As Integer
    Dim DataByteToRead As Integer
    Dim DataTime(4) As Long
    Dim Speed As Long
    Dim MaxSpeed As Long
    Dim RPM As Long
    Dim RPM_Max As Long
    Dim RPM_poles As Long
    Dim Volt As Single
    Dim TempC As Single
    Dim RxVolt As Single
    Dim Altitude As Single
    Dim AltitudeInt As Long
    Dim AltitudeSign As Long
    Dim Name As String
    Dim Current As Single
    intFileNum = FreeFile
    intCellRow = 1
    Set dlgSaveAs = Application.FileDialog(msoFileDialogOpen)
    ' Update the file name!!!!
    SourceDir = "F:\kim\rc\DX8\sd_log"
    dlgSaveAs.InitialFileName = SourceDir
    dlgSaveAs.AllowMultiSelect = False
    dlgSaveAs.Filters.Clear
    dlgSaveAs.Filters.Add "Spektrum log data", "*.tlm", 1
    dlgSaveAs.FilterIndex = 1
    'dlgSaveAs.
    dlgSaveAs.Show
    If dlgSaveAs.SelectedItems.Count = 1 Then
        SourceDir = dlgSaveAs.SelectedItems(1)
        Open SourceDir For Binary Access Read As intFileNum
    Else
        Exit Sub
    End If
    ' Read data
    intCellRow = 1
    ' Reset controls
    DataMode = 0
    DataByte = 0
    DataByteToRead = 20
    ' Reset info
    DataTime(1) = 0
    DataTime(2) = 0
    DataTime(3) = 0
    DataTime(4) = 0
    Speed = 0
    MaxSpeed = 0
    RPM = 0
    RPM_Max = 65000
    RPM_poles = 12 ' update this to match your flight
    Volt = 0
    TempC = 0
    RxVolt = 0
    Altitude = 0
    AltitudeInt = 0
    AltitudeSign = 0
    Name = ""
    Current = 0
    Do While (Not EOF(intFileNum)) And intCellRow <= 100000
        Get intFileNum, , bytTemp
        DataByte = DataByte + 1
        Select Case DataByte
        Case 1 ' Time Low
            DataTime(1) = bytTemp
        Case 2 ' Time
            DataTime(2) = bytTemp
        Case 3 ' Time
            DataTime(3) = bytTemp
        Case 4 ' Time High
            DataTime(4) = bytTemp
            If (DataTime(1) = 255) And (DataTime(2) = 255) And (DataTime(3) = 255) And (DataTime(4) = 255) Then
                DataTime(0) = 0
                DataMode = -1
                DataByteToRead = 36
            Else
                DataTime(0) = DataTime(1)
                DataTime(0) = DataTime(0) + (DataTime(2) * CLng(256))
                DataTime(0) = DataTime(0) + (DataTime(3) * CLng(256) * CLng(256))
                DataTime(0) = DataTime(0) + (DataTime(4) * CLng(256) * CLng(256) * CLng(256))
                DataByteToRead = 20
            End If
        Case 5 ' Mode
            If DataMode <> -1 Then
                DataMode = bytTemp
            End If
        Case 6 To 36
            Select Case DataMode
            Case -1 ' Header
                Case 6
                    Name = ""
                    If bytTemp = 0 Then
                        DataMode = -2
                    End If
                Case Else
                End Select
            Case -2 ' Header
                Case 13 To 22
                    Name = Name & Chr(bytTemp)
                Case Else
                End Select
            Case 3 ' Current
                Case 6
                    Current = 0
                Case 7
                    Current = bytTemp * CLng(256)
                Case 8
                    Current = Current + bytTemp
                    Current = Current * 0.1976
                Case Else
                End Select
            Case 17 ' Speed
                Case 6
                    Speed = 0
                    MaxSpeed = 0
                Case 7
                    Speed = bytTemp * CLng(256)
                Case 8
                    Speed = Speed + bytTemp
                Case 9
                    MaxSpeed = bytTemp * CLng(256)
                Case 10
                    MaxSpeed = Speed + bytTemp
                Case Else
                End Select
            Case 18 ' Altitude
                Case 6
                    Altitude = 0
                    AltitudeInt = 0
                Case 7
                    AltitudeInt = bytTemp * CLng(256)
                Case 8
                    AltitudeInt = AltitudeInt + bytTemp
                    AltitudeSign = AltitudeInt And &H8000
                    AltitudeInt = AltitudeInt And &H7FFF
                    If AltitudeSign = 32768 Then
                        Altitude = AltitudeInt - 32767
                    Else
                    End If
                    Altitude = Altitude / 10
                    If (Altitude > 1000) Or (Altitude < -1000) Then
                        Altitude = 0
                    End If
                Case Else
                End Select
            Case 126 ' RPM,Volt,Temp
                Case 6
                    RPM = 0
                    Volt = 0
                    TempC = 0
                Case 7
                    RPM = bytTemp * CLng(256)
                Case 8
                    RPM = RPM + bytTemp
                    If (RPM = 65535) Or (RPM < 200) Then
                        RPM = 0
                    Else
                        RPM = (120000000 / RPM_poles) / RPM
                    End If
                Case 9
                    Volt = bytTemp * CLng(256)
                Case 10
                    Volt = Volt + bytTemp
                    Volt = Volt / 100
                    If (Volt > 100) Or (Volt < -100) Then
                        Volt = 0
                    End If
                Case 11
                    TempC = bytTemp * CLng(256)
                Case 12
                    TempC = TempC + bytTemp
                    TempC = (TempC - 32) / 1.8
                    If TempC > 500 Or TempC < -100 Then
                        TempC = 0
                    End If
                Case Else
                End Select
            Case 127 ' Radio,RxVolt
                Case 6
                    RxVolt = 0
                Case 19
                    RxVolt = bytTemp * CLng(256)
                Case 20
                    RxVolt = RxVolt + bytTemp
                    RxVolt = RxVolt / 100
                Case Else
                End Select
            Case Else
            End Select
        Case Else
            DataMode = 0
            DataByte = 0
        End Select
        ' Print data
        If DataByte >= DataByteToRead Then
            If DataMode = 127 Then
                intCellRow = intCellRow + 1
                Cells(intCellRow, 1) = DataTime
                Cells(intCellRow, 2) = Speed
                Cells(intCellRow, 3) = MaxSpeed
                Cells(intCellRow, 4) = RPM
                Cells(intCellRow, 5) = Volt
                Cells(intCellRow, 6) = TempC
                Cells(intCellRow, 7) = RxVolt
                Cells(intCellRow, 8) = Altitude
                Cells(intCellRow, 9) = Current
            End If
            If DataMode = -2 Then
                ' Nyt ark
                Sheets.Add After:=Sheets(Sheets.Count)
                Sheets(Sheets.Count).Name = Sheets(Sheets.Count).Name & " " & Name
                Cells.Select
                Selection.ClearContents
                Columns("A:A").Select
                Selection.NumberFormat = "0"
                Columns("B:B").Select
                Columns("C:C").Select
                Columns("D:D").Select
                Columns("E:E").Select
                Selection.NumberFormat = "0.00"
                Columns("F:F").Select
                Selection.NumberFormat = "0.0"
                Columns("G:G").Select
                Columns("H:H").Select
                Columns("I:I").Select
                Cells(1, 1) = "Time stamp"
                Cells(1, 2) = "Speed"
                Cells(1, 3) = "MaxSpeed"
                Cells(1, 4) = "RPM"
                Cells(1, 5) = "Volt"
                Cells(1, 6) = "TempC"
                Cells(1, 7) = "RxVolt"
                Cells(1, 8) = "Altitude"
                Cells(1, 9) = "Current"
                ' Read data
                intCellRow = 1
                ' Reset controls
                DataByteToRead = 20
                ' Reset info
                DataTime(1) = 0
                DataTime(2) = 0
                DataTime(3) = 0
                DataTime(4) = 0
                Speed = 0
                MaxSpeed = 0
                RPM = 0
                Volt = 0
                TempC = 0
                RxVolt = 0
                Altitude = 0
                AltitudeInt = 0
                AltitudeSign = 0
                Current = 0
            End If
            DataMode = 0
            DataByte = 0
        End If
    Loop
    Close intFileNum
End Sub
Sep 04, 2012, 06:20 AM
Surface, Air & Water Rc Toys..
Interesting, are you working on a program of some sort?
Sep 04, 2012, 07:37 AM
No, not a program, but i need a way to read the log with out using iOS device.
And Excel can make the view I need. Thats way I made the VBA script to read the file.
If there is some having SPEKTRUM.TLM files with info from other sensor then Speed, RPM, Volt, Temp, RxVolt, Altitude then pleas upload them and i will try to find the information and add them to the script.
Sep 04, 2012, 10:19 AM
I think I can provide some more info from the other side. I currently play around with the TM1000 side to substitute various sensors
The data is gathered from the sensors with an IC interface. 16 bytes, the first is the device, second is 00. Then 14 bytes of data..
03: Current. (A)
00
MSB
LSB
and the rest is 00
one unit of current is 0.1976A. A little bit strange, seems to be related to the used current sensor.
Adress 0a is Powerbox.
I will post the rest the next days when I am finished hacking
Maybe you can create a converter to geht the data into LogView ?
Sep 04, 2012, 10:30 AM
Thangs for the info
I have update the import function to devide the logs.
Sep 04, 2012, 03:32 PM
When import to excel it can look like this when make a diagram.
Sep 04, 2012, 04:11 PM
Nice, almost looked like I was looking at my CC Ice log files.
Keep up the good work, I am sure many will be interested.
Sep 04, 2012, 05:03 PM
Great job.....
Sep 06, 2012, 06:11 AM
egicar's Avatar
Originally Posted by faxxe
great job.....
+1 Subscribed.
Sep 06, 2012, 06:05 PM
First version of a converter to LogView
Hi
Hir is my first version of a converter to convert Spektrum log file (SPEKTRUM.TLM) to a LogView format.
When more ready I will also provide the source code.
Kim
Sep 07, 2012, 12:46 PM
SPEKTRUM.TLM files for test
Hi
I need SPEKTRUM.TLM files to test my program pleas upload if you have one that have other sensor then Speed, RPM, Volt, Temp, RxVolt, Altitude.
Sep 09, 2012, 09:48 AM
I was out flying to day, and this is a log of a takeoff.
Sep 10, 2012, 02:20 AM
egicar's Avatar
I'm sorry: I don't have a rich TLM file: I have the TM1000/1100 stock sensors .
You are making a very good work!!!
Maybe, we need some more instructions about using your program.
Here is what I did:
  1. I opened my Spektrum.TLM file and saved the CVS files in a directrory
  2. I launched LogView and imported the CVS
  3. I saved the file in LogView format (LOV)
Is this the right way?
Ciao,
Egidio
Discussion Format of DJI Wookong Ground Station log files ? sPiKes777 Multirotor Drone Electronics 43 Oct 13, 2016 08:10 AM
Sold NEW Spektrum DX8 Transmitter DSMX W/charger and sd card HD Hucker Aircraft - General - Radio Equipment (FS/W) 0 Aug 28, 2012 01:59 PM
Sold NEW Spektrum DX8 Transmitter DSMX W/charger and sd card HD Hucker Aircraft - General - Radio Equipment (FS/W) 3 Aug 27, 2012 07:55 PM
Sold Spektrum DX8 Transmitter w/Charger and SD Card! NEW HD Hucker Aircraft - General - Radio Equipment (FS/W) 2 Aug 24, 2012 12:28 PM
Discussion DX7s (perhaps DX8) SD card storage format editor? A Useless Geek Radios 54 Jan 03, 2012 01:27 AM
