Dec 30, 2019, 03:27 AM
when is the wind stopping??
markkona's Avatar
Originally Posted by Cpt.Abraham
Well if he could make it in small Yaris, it can sure fit in my car
Tnx for the info mate.
The yaris sedan isn't a lot smaller than a 3series bmw
Jan 09, 2020, 03:31 AM
Cpt.Abraham's Avatar
[QUOTE=markkona;43478877]The yaris sedan isn't a lot smaller than a 3series bmw [/Q
You are right
Have you used flaps on takeoffs and landings?
Also, what throws or expo did you use?
Finally, this is my first plane with flaps. Any advice how to use them? Maybe mix them with down elevator?
Tnx
Jan 10, 2020, 03:58 AM
markkona's Avatar
[QUOTE=Cpt.Abraham;43556521]
You are right
Tnx
On take offs flaps always on. You need to add between 10 to 15% down elevator with flaps as it will balloon up when deployed. I always like to use about 45% expo on all my models for the maiden and then obviously adjust afterwards depending how fast the model reacts to stick movements
Jan 13, 2020, 02:21 AM
[QUOTE=markkona;43564833]
Tnx for the reply.
So full flaps on take off with 10-15% mix down elevator?
How about landings?
Jan 13, 2020, 03:58 AM
markkona's Avatar
[QUOTE=Cpt.Abraham;43586591]
Tnx for the reply.
How about landings?
The plane slows down a lot I never needed flaps to land but you can try doing a few high flybies with flaps deployed to see how the plane behaves with them in the air. I did not like flaps deployed while landing as it totally changed the flight characteristics whilst turning /banking at slow speeds to come in for landing.
Jan 23, 2020, 12:54 AM
AR6100 placement
Just bought a used Island Wings Beaver and will be putting in my ar6100. Anyone have suggestions as to the best location. Iím not sure if it needs to be away from esc, battery, etc....
Jan 23, 2020, 10:31 AM
I will have to take a look to see where I placed mine, but if you did not get a user manual, you can get one here: https://www.horizonhobby.com/pdf/FLZA4024-Manual-EN.pdf
Here is the supplement that shows where to put the receiver: https://www.horizonhobby.com/pdf/FLZ...plement-EN.pdf
Jan 23, 2020, 08:10 PM
Ghost Rider the pattern's full
santanig5's Avatar
Mine is behind the seats, on the servo tray.
Sent from my SM-G960U using Tapatalk
Jan 24, 2020, 01:02 AM
Perfect! Thanks
Jan 24, 2020, 08:38 AM
Mine is where they suggested in the directions.
Jan 24, 2020, 11:57 AM
Mine is near the battery.
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Scale Kit/Scratch Built 16 Jun 09, 2016 07:24 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Scale Fuel Planes 2 Jan 05, 2008 02:26 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Giant Scale Airplanes 1 Dec 31, 2007 04:39 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Parkflyers 3 Dec 29, 2007 08:32 PM
Discussion Dehavilland beaver DHC-2 Mk 3 peterpont Giant Electric Planes 1 Dec 29, 2007 07:39 AM
