Aug 29, 2012, 11:00 PM
New Product
RC4Y 5.8 GHZ 1200MW transmitter and Receiver customize for FPV,can be used fatshark
Working Frequencies: (Can be used for Fatshark)
5720MHz
5740MHz
5760MHz
5780MHz
5800MHz
5820MHz
5840MHz
5860MHz
5880MHz
TX spec.:
Weight: 65g
Dimension: 70*38*18.5mm
Working Voltage: DC12V
Working Current: 700mA
Working Frequency: 5.8G
Working Channels: 9CH
Output Power: 1200mW
RX spec.:
Weight: 67g
Dimension: 72*43*11mm
Working Current: 200mA
More,http://www.rc4y.com/rc4y-58-ghz-1200...ark-p-483.html
Sep 04, 2012, 03:57 PM
tushev's Avatar
Just order it from you.
Sep 05, 2012, 12:04 PM
mecevans's Avatar
What is the data pin for?
Sep 05, 2012, 04:01 PM
tushev's Avatar
second video IN, I guess..?
Sep 14, 2012, 10:36 AM
Great Britain
MrBen.'s Avatar
RC4Y is untrustworthy I wouldnt buy anything from them.
Sep 14, 2012, 11:10 AM
tushev's Avatar
Let see, I hope you are wrong !
Sep 27, 2012, 03:27 AM
Ltomi78's Avatar
We have tested this setup. Theirs huge problem with the reciver, bacause it has interference with 2.4 ghz rc system, when the RC transmitter is close within 1m to this 5.8 receiver. If you are far than 1 m it is godd but only for 800m range, when interference appear again.
See test video, the jumping screen with lines (similar what can couse in a 2.4 video receiver). The tx was in garage, the reciever was on the second floor in the house, the 2.4 flysky rc transmitter was 60cm-1m near to 5.8 video receiver.:
084546 (1 min 20 sec)
Transmitter was also tested on 800-1000 m range by my friend where interference occur again.
Sep 27, 2012, 09:09 AM
tushev's Avatar
So look like the RX filtering is not so good. Try diferend channel for instance? How is working with the Fatsharks integrated RX module?
Sep 27, 2012, 09:16 AM
Ltomi78's Avatar
hI!
All the channels on this patrom recieiver are sensitive for 2.4 rc radio, we try all of them, but lower band 5720 a little less sensitive. I dont have fatshark, as I know fatshark integrated 5.8 video receivers has no problem with 2.4 Rc radios. or you heard other about it?
Do you have any solution to decrease interference or sesitiveness to 2.4 on this receiver?? (you got in the package with 1200mw video tx).
I cant find other videos and real reviews with field test with this receiver.
maybe i should by fatshark or immersion well -know 5.8 receivers..
You can buy also here. Much more reliable than r4yc.
http://www.electronicarc.com/catalog...c7edd9e76ddb6f
you can see here, that the data port can be used to swith channle on 5.8 video tx in the air. you can connact data in port GND and R/C (data in) with your one of your channel of your rc receiver GND and PPM. If I'm well...you can see the schematic in an other 1.3ghz tx with sama data port:
do you know how to understand this?
The transmitter has 1 connector (up) with 4 connections wires:
* Red: OUT 12V br> * Black: GND
* Yellow: R/C
* White: no used
red out with black...i thin i need to use only gnd and ppm with blakc and r/c
am i right?
Sep 27, 2012, 09:22 AM
tushev's Avatar
Just got mine yesterday. I will test it with the F.Sharks soon..,I will try tonight!
Sep 27, 2012, 09:26 AM
tushev's Avatar
I am sure immersion will work well since Sander is filtering manniak
Sep 27, 2012, 09:31 AM
Ltomi78's Avatar
Cool.. can you test it with their own receiver also.. if you find also interference if you cloe rc 2.4 radio to this receiver?
SOME INFO:
* Yellow: R/C
* White: no used
am i right?
Sep 27, 2012, 08:09 PM
tushev's Avatar
Just tested with Fatsharks integrated 5.8mHz Rx - Zero interference , I am blasting 2W from boosted Futaba FASST radio almost touching the antennas.
Yes the stock Rx is picking interference from 2.4gHz radio big time.
Sep 28, 2012, 02:11 AM
Ltomi78's Avatar
Anybode know how to change remotely the channels on this video tx.
http://electronicarc.com/~s0350672/c...%20V.2%20a.jpg
This tx has same double port. One for changing channels.
Based on the picture I shoud make somehow a electricshortcut between GND and R/C pin , wicih provide the same impact as I push the channel swith button?
How can I make this?????
I got answer form ElectronicaRC
"Hello,
We will have available next month an interface that allow to connect data
port with RC receiver and change channels.
Yes, video receivers must always be at least 3m away from any transmitter
device for a longer range.
Best regards,
Eladio"
ElectronicaRC
SOME INFO:
* Yellow: R/C
* White: no used
am i right?
Dec 05, 2012, 07:25 PM
LiutaS's Avatar
Any range test with this tx?
Wanted Fatshark Predators and 1.3/5.8 GHz FPV equipment Zangetsu57 FPV Equipment (FS/W) 3 Dec 21, 2012 10:25 PM
Discussion 5.8 GHz 200-900mw + Fatshark goggles: Is this a good first FPV setup? VuzeDroid FPV Talk 18 Aug 14, 2012 04:21 AM
Discussion RC4Y 5.8G 200mW transmitter for FPV free shipping RC4YFPV Hot Online Deals 6 Jun 13, 2012 09:23 PM
Found 5.8 GHz FPV setup (w/ Fatshark if possible) MCrites FPV Equipment (FS/W) 2 Mar 26, 2012 12:02 PM
Sold ImmersionRC 600mW 5.8 GHz Transmitter - Fatshark compatible sharonx FPV Equipment (FS/W) 1 Mar 26, 2012 11:53 AM
