Nov 23, 2003, 08:39 PM
Experienced R/C Repairman
barnyardflyer's Avatar
My Southern 2 kit by Mark Roberts build
I first wrapped the wing skin around a couple of cardboard tubes from Solar wing coverng.
I did this to train the EPP to curve to this position. IT WAS SCARY TO FOLD OVER, FELT LIKE IT WOULD BREAK, BUT IT DID NOT. WHEW!!!
Nov 23, 2003, 09:16 PM
I then drove to different stores in my nearby larger city, looking for sutiable glues.
I could not find Goop Marine anywhere.
I found a contact cement made by Locktite, and I am going to use that. Label says "Sets in 1 second"
I decided to install two 1/8" x 16" carbon fiber tubes in the top and bottom of the wing spar.
I cut a groove in each edge of the spar, with my rotosaw, so they would be flush with the inside wing skin surface.
I placed the 2 center ribs 2 1/4" between centers, and the others 3 1/2" between centers from each center rib.
I also rounded both ends of the spar, so i could fold over the wing skin smoothly. (I hope!}
Nov 23, 2003, 09:19 PM
Bottom
Nov 23, 2003, 09:32 PM
In case anyone is wondering, I made a fence for my rotosaw, using spring clothes pins.
Nov 23, 2003, 09:47 PM
Fly it like you stole it..
Tram's Avatar
Ahh lookin good!
Nov 23, 2003, 10:35 PM
I then decided to glue just the front rib tips to the inside wing skin.
I looked like the ribs would have an air gap if I didn't.
Nov 23, 2003, 10:55 PM
I then glued the bottom edges of the ribs and spar to the wing skin.
Nov 23, 2003, 11:00 PM
Real Men Fly Pink Planes...
kepople's Avatar
Looking good BYF!!
So since you are using contact cement, are you having to apply glue to both surfaces?
What is the sure time before you can contact the pieces?
Kirby
Nov 23, 2003, 11:18 PM
Then I glued the top.
Nov 23, 2003, 11:26 PM
Thanks guys,
Yes I am putting the cement on both surfaces, then I press them together, then seperate for 15 mintutes, then attatch very carefully. The contact is instant. No room for error.
Nov 23, 2003, 11:27 PM
And You're Not
Looks pretty dang solid to me. Good work.
Nov 24, 2003, 12:02 AM
Total weight of completed wing is 2 1/4 ozs.
Nov 24, 2003, 12:17 AM
rpvpilot's Avatar
Don't leave us hangin', hurry up and build dang it, BUILD!
Nov 24, 2003, 12:20 AM
Oh, by the way, glueing the wing tips came out so-so in my opinion.
Should fly fine though.
Nov 24, 2003, 12:26 AM
I'm building as fast as the contact cement will allow.
Time for bed now, It's 12:25 AM in Michigan.
I wish I didn't have to spend the whole day shopping, not only for glue, but Christmas stuff as well. (Have to keep the lady happy!)
More tomorrow
