Aug 19, 2012, 03:56 PM
Nexus21214's Avatar
Help!
KK 2.0 LCD board PIEZO plug in ?
Hi Guys
I now have my new Y6 950mm set up and 90% stable and flying ok
I have a couple of questions if anyone can help.
I have reduced the pgain to 125 and this has removed almost all of the oscilations. I still have a very slight oscillation on aileron channel. Should I reduce pgain further to remove ? or is a tiny bit of oscillation normal ?
On self leveling setting I have currently 35 p-gain 20 i-gain 0, 0, Does increasing the p gain value increase self self leveling?
When the board arrived it came with a Low Volts piezo buzzer. I have set board at 105 or 10.5v
However I cant find where to plug the piezo buzzer in ? I notied on the board there is a two pin parked piezo at the front left of the board. Is this where I plug in ? and if so which is Positive (red) the left or the right pin ? when viewed from the back of the board. Or does in plug in somewhere else ?
The manual does not indicate when to connect the piezo and nor do any of the vids I have found so far.
Any help or advice is appreciated
Regards and thanks
Nexus
Aug 19, 2012, 05:01 PM
There's really not much point in doing this unless you actually bother to wire up the LiPo battery to the Battery Voltage monitor.
Underside, on the left-hand side there is GND pad and another hole for +ve connection (just above AREF)
However I cant find where to plug the piezo buzzer in ? I noticed on the board there is a two pin parked piezo at the front left of the board. Is this where I plug in ? and if so which is Positive (red) the left or the right pin ? when viewed from the back of the board. Or does in plug in somewhere else ?
Not too tricky this, the board pins are marked BZ+ (the + bit indicates +ve) and the piezo buzzer wires are colour coded - red goes to +ve
Aug 19, 2012, 05:16 PM
It's a job...
747Pilot's Avatar
z
KK2 Voltage Alarm Setup (7 min 21 sec)
Discussion Y6 with kk.2.0 LCD board PID settings wanted please Nexus21214 Multirotor Drone Talk 1 Aug 16, 2012 05:59 PM
Sold KK 2.0 board, new and unflown Blucross Aircraft - Electric - Multirotor (FS/W) 2 Aug 03, 2012 08:57 PM
For Sale KK 5.5 board w/loaders--Crius LCD--NEW ldm1839 Aircraft - Electric - Multirotor (FS/W) 4 Jun 28, 2012 08:33 PM
Sold 3- KK Plus Boards plus LCD & USB Programmer Price Lowered Chad2323 Aircraft - Electric - Multirotor (FS/W) 4 Mar 08, 2012 09:18 PM
For Sale KK Board 5.5e with LCD and MKUSB LInker for KK+ pajonate Aircraft - Electric - Multirotor (FS/W) 2 Mar 04, 2012 09:59 PM
