Jul 10, 2014, 08:35 AM
Innovator
danford1's Avatar
It looks like it has a molded under camber wing. Is that a kit or scratch built?
Danford1
Jul 10, 2014, 03:18 PM
Gravity is my enemy
Balloon Bandit's Avatar
Slow flight
The slowest flight, hmmmm. Perhaps Helium should be involved
Jul 10, 2014, 05:07 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
This one could be INCREDIBLY slow with helium
Balloons flyer 風船飛行機 (2 min 1 sec)
Jul 10, 2014, 07:26 PM
Haoyang Wang's Avatar
Wow, so inventive! Thanks for sharing.
I don't see helium being used. Just regular air.
Jul 10, 2014, 09:25 PM
Yeah , just think how slow it COULD be with helium !
Jul 11, 2014, 02:40 AM
Danford1
hello danford1,
it's scratch build. 3mm depron, bended with heat gun.
Plans are here:
http://www.roberts-r2d2-bau.de/downl...Motor_Wing.pdf
http://www.roberts-r2d2-bau.de/downl...Motor_Rips.pdf
The rips (Frame 1 - Frame 4) were only used as rough templates.
It was not my own idea. I was inspirated by https://www.rcgroups.com/forums/showthread.php?t=67042
Jul 11, 2014, 04:02 AM
Markran's Avatar
Yes, but remember hydrogen is even more buoyant than helium.
http://en.wikipedia.org/wiki/Lifting_gas
Jul 11, 2014, 04:11 AM
Markran's Avatar
If we're looking for the slowest airplane flight then I think the current leader in the pre-assembled, store-bought, inexpensive category may be the $99 AS3xtra at 36 grams / 2.5 ounce /sq ft wing loading. Mine flies around about as slow as that balloon plane.
Jul 11, 2014, 02:26 PM
Well, AS3xtra can hover around like a helicopter...
When you fly your AS3xtra, do you have all the lift coming from the wings, or do you use prop-hang too?
Don't forget Vapor and Mini-Vapor.
Jul 11, 2014, 03:06 PM
The OP of this thread was looking for a slow flying plane that flies on the wing , not hanging on the prop - basically the lightest possible wing loading .
Jul 13, 2014, 07:31 AM
CG =Airplanes .. COG's = Gears
Although not the "Slowest Of The Slow" this DR1 from the Park Flyer board should be worth consideration. Very nice design by jetset44 from almost 10 years ago.
Mine flies and lands at air speeds similar to my Slowly and Magnum.
Built with FFF and powered with a Park 450. Very light, flies great and withstands the abuse I put it through.
https://www.rcgroups.com/forums/showthread.php?t=425387
If you'd like a slow flyer for the local park check it out.
Regards,
Connie
Dec 06, 2014, 01:47 PM
Slow 1s powered
For all you slow flight fans , here is a 1s powered plane , now available in a kit .
https://www.rcgroups.com/forums/show....php?t=2298587
Deutsche Meisterschaft F3P Mannheim - Donatas Pauzuolis - Expertklasse Lauf 1 (4 min 23 sec)
Dec 06, 2014, 02:36 PM
An itch?. Scratch build.
eflightray's Avatar
The bigger they are the slower they look --
Spectacular HUGE RC plane. 16 square meter wing SLOW MFK FALKEN (11 min 23 sec)
Dec 06, 2014, 02:56 PM
juzchillin's Avatar
ewo's amos.
http://www.ewovids.rchomepage.com/am...zeamos-1-1.mpg
Dec 06, 2014, 03:29 PM
Originally Posted by juzchillin
Very cool !
Discussion Let's get APC to make a 13x4.7 slow flyer pusher! Mactadpole Multirotor Drone Talk 6 Apr 24, 2012 09:55 PM
Sold Crashed E-flite S.E.5a Slow Flyer 250 $40 shipped haines74 Aircraft - Electric - Airplanes (FS/W) 2 Mar 30, 2012 12:46 AM
Sold e-fLITE S.E.5a Slow Flyer 250 ARF vcaruso Aircraft - Electric - Airplanes (FS/W) 2 Feb 25, 2012 08:32 AM
Discussion Slowest Slow Flyer? Anyone surpassed the Gym-E? Tram Parkflyers 5 Sep 15, 2006 08:03 PM
slowest, cheapest slow flyer rcboy Parkflyers 40 May 15, 2006 08:29 PM
